Trouble with eureka prom when using volume pedal
Hi everybody,
I installed an eureka prom in my behringer fcb1010 ... so far. The fcb is connected via midi directly to 11rack ... the 11rack goes via usb to my win7 pc. everything is working fine - but when I am using the volume pedal my ProTools (10.3.2) crashes and I have to reboot my computer. any ideas ... ? thx Peter |
Re: Trouble with eureka prom when using volume pedal
Sounds weird.
What happens if you use the mouse to adjust the position of the Volume pedal in the 11R On-Screen editor? What happens if you use the front panel of the 11R to adjust the volume pedal? Do those crash Pro Tool? Is the MIDI passing into Pro Tools and adjusting parameters in PT? Have you tried updating to the latest version of PT10?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Hi benoni,
thx for answering ... I will try it tomorrow and tell you. good ideas ! |
Ok ... I tried it out...
it just happens when I´m on an instrument track in PT with my Superior Drummer on. Another instrument track with xpand on is in reaction with the volume pedal of my FCB. there I can control my volume on x-pand .... the 11rack is on Mmidi channel 1, fcbs midi is unknown ... my instrument track with superior drummer is played by my TD-10 (channel 10) that drives me crazy ... ??? |
.... and.... it also happens when my 11 has volume pedal "off"
just one touch on the pedal .... while my instrument track is choosen ... and PT crashes .. |
Free FCB1010 Eureka! PROM | cage77 | Eleven Rack | 1 | 11-10-2013 03:41 AM |
11R with FCB1010 & Eureka Prom | rexrandom | Eleven Rack | 1 | 10-12-2013 02:41 PM |
I have no idea how to use fcb1010 and eureka prom | mesaman4 | Eleven Rack | 2 | 03-07-2013 08:24 PM |
Eureka Sound Prom question | texasdave | Eleven Rack | 2 | 07-23-2012 01:30 PM |
Eureka prom installed but the exp pedal wont calibrate right | Jd0g33 | Eleven Rack | 4 | 12-02-2011 01:23 PM |
