Pro Tools 6.4 for Live Situation
Ok, so I do live sound for a worship band out at my church. It's a contemporary service with a rock band and such. NExt week they will be playing a show outside of the church, and I'm not sure what to do because the board we use at the church is a 24-channel, 8-bus behringer board. Nothing too fancy, I know, but we only use 12 channels, and I can't see the purpose of unplugging everything going into that board, lugging it on the road for a 2 hour show.
So, renting came to mind. But THEN, i thought about it yesterday and wondered.... could I set up 12 aux tracks going into my pro tools system (002r running 6.4, with a behringer adat 8-channel preamp) and send the signals out the outputs to a poweramp? would this work? I know my CPU can handle it, that's not the problem. My question to whomever will answer is, will I run into any problems that immediately come to mind? This should work, shouldn't it? Any suggestions or help would be greatly appreciated. Cory. |
Re: Pro Tools 6.4 for Live Situation
I think your setup should work fine. I know lots of people who use their DAW setups as effects processors live instead of bringing hardware racks to the show. The only thing that I would be concerned about is the system's latency. If you leave the 002r on 64 samples I imagine no one will notice a thing.
Pro Tools|24 Mix Plus 3 (6.4.1 cs4) G4 AGP Sawtooth with 1Ghz Sonnet Processor Upgrade 1.5 Gig of RAM. OSX 10.3.4 Command|8 |
Should work fine. Can you test in your church before you hit the road?
Renting a 12-16 channel board should cost you less than 50 bucks. I'd rather do that then yank my PT system and put my live sound in the hands of Bill Gates.
http://soundofthatday.com |
Acoustic in a Live situation... | leblanc74 | Eleven Rack | 3 | 04-09-2011 12:45 PM |
Midi Keyboard Live Situation - Help! | stev | Tips & Tricks | 2 | 10-13-2007 07:26 PM |
b4 in a live Situation | bassist | MIDI | 0 | 11-21-2005 08:28 PM |
recording in a live situation | Welcome To Roswell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-20-2005 09:55 AM |
Using a Digi001 in a live situation??? | Saberon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2003 08:34 AM |
