Pc brand names ?
Own a mini box. I would rather buy a PC brand name desktop for my PT. Any names out there that really work.
Thanx for the help ! |
Re: Pc brand names ?
Check out this thread.
vandergraf.net "All the truth in the world adds up to one big lie" :: Bob Dylan ¯ |
Yep...........they call it a Mac!
PT 9 Control 24 003 Rack Mac Pro 2.66 Quad Adam A7 Waves Gold, VSeries Pultec Bundle URS, McDSP |
As a long time PC user, I have to agree. If you want an off the shelf system, buy a MAC.
www.M-ManLA.com www.facebook.com/MManLA www.soundcloud.com/m-manla Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro |
Does it have to be a brand name? You can build a $1500 PC for about $800 from parts on Newegg. The core 2 thread has tons of advice and test results of these systems. It will save you some cash and most likely be a better machine than what you were going to buy "name brand". Its not like Dell makes the parts, they are just piecing it together for you and adding proprietary crap that you don't want anyway.
q6600-ASUS P5K SE(P35),2GB Crucial BallistexDDR2 800,ASUS EN7200GS 256MB,80GbMaxtor-80GBWestern Digital,Samsung SATA DVD burner,Mbox2 PTLE 7.4cs7 |
Actually, check out the first post in this thread. Take the parts list to a computer store that someone you trust recommends. They will put it all together for you - and be sure there are no part substitutions. If they absolutely must make a substitution, ask about it here first. And make sure they load on Windows XP SP2. The computer will work with PT LE. If you go the Quad route, you will have more than enough "horsepower" for a long time. You will probably never max the computer out.
Getting an off-the-shelf computer is tricky since you have to be sure the motherboard chipset and a number of other components will work with PT LE. Just "getting a Dell" is not good enough. Even the Dell's Digidesign recommends will, a lot of the time, after a build revision by Dell - where the model number remains the same, but the parts inside change - then be incompatible with PT LE. Unfortunately, on the Windows side of things especially, you must be very careful that the computer you choose is fully compatible with PT LE. That's why nearly everyone here recommends you build one from the parts list provided by actual users who have built machines that are proven to be compatible with and work well with PT LE. As a double bonus, invariably a computer built from a parts list here will be cheaper than an off-the-shelf model from Dell or other maunfacturers and will run extremely well almost any other DAW that's Windows capable. Cheers,
Buying a PC "in store" is really not the best route. Things can and do change unannounced and DELL, HP etc has zero concern for whether those changes have any affect on PT-only their bottom line.
In the long run you will be much happier sticking with something thats known to work with PT and if your not comfortable putting it together yourself then have a local PC shop assemble it. This will get you the best of both worlds-a machine thats faster and cheaper than store bought plus some technical expertise in case of some major hardware issue When you have problems with your store bought machine DELL or HP are not going to be much use to you. You will end up here on the forum asking for help. Which is freely given and often quite good! The store bought stuff is a crapshoot. Right chipset/Wrong FW chip. Fast Processer/Slow memory. Proprietary BIOS or parts that are hard to replace ETC. You can't beat the big players prices for email and multimedia systems but a DAW is a very special peice off equiptment and its best to know EXACTLY how its going to work. Having a 20 or 30 forum buddies with the same exact rig helps to troubleshoot problems that much faster.
Weed, your advice is excellent. This sentence made me smile though!
Sequential 1983: Who'd need more than 16 MIDI channels? Sun Studios 1957: Who'd need more than one mic? |
First of all, thanx to everyone.
Brand name ? Go for a mac. PC ? Buy the right parts instead of a Dell or HP. Correct ? By the way , which mac ? Thank you ! |
Brand new Mbox, Brand new pro tools LE 7.4. "unable to locate digidesign hardware" | eltore23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-03-2012 10:13 AM |
Unable to get Pro Tools 8.0 to launch w/ brand new Mac Pro and brand new 003 | ohheyandrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2009 10:18 PM |
The brand new HD with brand new Mac won't launch... | Rammelt | Pro Tools TDM Systems (Mac) | 9 | 07-18-2007 03:25 AM |
OMS names vs Free Midi names | ShivaTribe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2001 02:57 AM |
PT5 & OMS Names Manager (MIDI patch names) | Baron Von Deca | Tips & Tricks | 0 | 02-17-2000 03:55 PM |
