Pro Tools LE 6.1.2 (and 6.1.1) no longer work
Here's my setup: mBox, PowerMac G4 DP 1.25 GHz w/1 gig of RAM, OWC 7200 rpm Oxford 911 external FWD, Pro Tools LE 6.1.2, OS X 10.2.8.
Here's my problem: When opening Pro Tools 6.1.2, it either quits while opening the application or freezes (and totally locks up my computer necessitating a forced reboot) while opening a session. This just starting happening. I've had the 6.1.2 installed since it came out and was running with no problems--though with more frequent "Out Of CPU" messages. (With only two tracks and no more than three or four plug-ins on a master fader, this should not be.) The day the whole thing crapped out, I was getting frequent "Out Of CPU" messages. So I changed CPU usage to 99% and Sample Rate to 1024. Now I can't use 6.1.2 at all. (BTW, I did not install anything new on my computer or on Pro Tools the day all this happened. And yes, I tried trashing Pro Tools preferences.) I downgraded to 6.1 and everything works fine. (In the process of downgrading, then progressively upgrading, I found that 6.1.1 as well as 6.1.2 created the same problem.) I've e-mailed Digi Tech Support but thought I'd post here and see if anyone had any help/advice. I find this very baffling.
Mbob |
Re: Pro Tools LE 6.1.2 (and 6.1.1) no longer work
David Austin p4 3ghz, PT 6.4, XP, Digi002r, AMT8, Mackie Control |
002 buttons no longer work? | Jay002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-22-2011 07:07 PM |
It Would Appear As Though Emagic TDM Plug Ins No Longer Work | ChaplainPC | Pro Tools TDM Systems (Mac) | 7 | 09-14-2009 01:52 PM |
I can no longer get pro tools to work with reason! | tamashii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-14-2006 10:57 AM |
Oh what have I done....My midi sync no longer work | geraldg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-02-2004 09:00 AM |
How do the Longer Cables work for 001? | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-13-2002 04:55 PM |
