Weird solo behavior
For some reason the standard soloing behavior is not working at all on one of my sessions.
If I choose SIP as my solo mode I'm unable to solo anything...literally nothing will solo at all. If I change solo mode to AFL then I can solo as expected except solo safe dose not work...if I command click on an aux track solo button, the track volume fader appears... I tried option, command clicking on all the solo buttons and then, when in SIP mode, pressing a solo button on any track mutes the entire mix. SIP in all my other sessions work as expected.. Very, very odd.. Does anyone have a clue as to why this has happened? Thanks, LC __________________________________________________ __________________________ 2018 mac mini- macOS monterey 12.6, 3.2 GHz 6-Core Intel Core i7, 32 gb ram, PT 2022 10.0 |
Re: Weird solo behavior
I have a clue. You might not have tried all the standard troubleshooting steps.
That's not just to throw it back to you. Prefs get messed up, etc, keyboard might be wonky, or got water on it, and a modifier held down. These questions are so random because you system info and steps already undertaken are absent: https://duc.avid.com/showthread.php?t=300050
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
In any event, thanks for your response.. LC
Hope that helps
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
That's actually very helpful...thanks.. I'm back to using PT after many years away and I'm certainly rusty with my kb shortcuts... and as you correctly postulated I am routing my mix through auxes as well as a print track. That being said, might there be a step by step way to get back to the default solo behavior? Thanks again, LC
I think you're seeing correct/default solo behavior. Just solo-safe the aux tracks you're routing through (and fx returns) and you should be good to go.
To be fair, this was the first session since returning to PT that used a more complex routing as well as folders (routing and otherwise), and it's quite possible I inadvertently did something that either can't be undone or corrupted something in the session. Subsequent sessions with similar routing and organization work as expected. I'll take some comfort in the mix sounding good, learn and move on... As an aside, I was using both Reaper and Luna extensively prior to my switch back to PT and in Reaper the soloing behavior is so intuitive by default that one rarely has to ask for any assistance using it. Incredible coding in that DAW.. Thanks again for your assistance., LC
Nothing is working as it has done for the last 15 yrs solo wise. Has something big changed that I missed?
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
..ok, think I've figured out one of the issues. The latest PT Ultimate has switched Solo behaviour to AFL that was previous set as SIP...my sessions have always been SIP, but when loading in an old session, *or* a template created with an older version, 2022.10.10 changes the solo behaviour...
8.0.4 New solo behavior? | Reckless Erik | Post - Surround - Video | 18 | 11-22-2016 04:26 AM |
Group solo behavior in 12.3.1 | tooold | Pro Tools 12 | 3 | 12-29-2015 10:09 AM |
aux solo behavior? | gdgross | Pro Tools 11 | 2 | 09-04-2015 07:40 AM |
FWx PT hangs, changes console solo behavior | Brent Lind | VENUE Live Sound Systems | 0 | 08-12-2012 03:48 PM |
SOLO behavior in PT 8 | Dopamine | Pro Tools TDM Systems (Mac) | 7 | 12-31-2008 08:37 AM |
