Control App Eucon group select varies every time
Pro Tools 2023.3.0 Control App Version: 2022.12.1.153 Eucon Version: 2022.12.1.34 Eucon Version: 4.10.3.34 Avid Artist Mix Through the app control, I have created an eucon command that selects the tracks in a group (select tracks in groups then group list). In the images you can see that when pressing the command several times the selection of channels varies. Is this is the normal behavior of the command through the app or a bug? Thanks,
Juan José Salazar Sonic Animal Music | Mixing and Mastering Pro Tools Studio 2023.3.0 RME Babyface | Antelope Zen Studio macOS Ventura 13.3.1 (a) | Macbook Pro M1 13" macOS Monterrey 12.0 | Mac Pro 2013 |
Re: Control App Eucon group select varies every time
You should post pictures of the macro you made in EuControl. Posting pictures of the soft key and results doesn’t help in trying to figure out if there are any errors in your custom command.
Hi its2loud,
I selected this 2 Eucon commands: select tracks in groups, then group list. The screenshots are attached. Thank you
It's you're trying to select the tracks in a particular group then reverse the order of those commands in Eucon.
Like shown in this picture. |
The problem with that sequence is it will first disable the group selected (I work with all groups enabled) and then it will send "select tracks in group" command, so you have to press the command again. Group will not be enabled, and the command will keep asking for a group to select.
Also, I have and artist mix and in this new sequence, sometimes groups selection are not consistent, if I have more than 8 tracks, at first banks the last 8 tracks, if I touch the command again it works randomly showing between the 8 last banked or sometimes the first 8, this behavior is not showed in the Control App. I think the best workaround is to have those 2 commands independent.
Try disabling the preference “auto-bank to selected track" and see if that changes anything. Last edited by its2loud; 05-07-2023 at 10:39 AM. |
Workflow:
1. I want to select tracks in control app (all tracks are in groups) 2. Show those tracks in Artist Mix (it will bank the last 8 of the selection, I think it's by default). 3. Show those selected tracks in Edit Window in Pro Tools. I think also by default it shows only the last bank, so if I have 12 tracks selected it will show at the top of the windows only the last 4 tracks I want to achieve that those 12 selected tracks show in Edit Window when I push the command in Control App The random behavior that I refer of, was found while trying to achieve this workflow. If I disable “auto-bank to selected track" then the Artist Mix won't follow the Control App
Ok. Thanks for the clarification. This sounds like the long approach to alternatively working with folder tracks or VCA’s. Either of those will give you a spill function for the tracks you’re trying to bring into focus in PT and on the surface. Alternatively, you can work with layout on the surface.
I assume you have “Edit Window Follow Bank Selection” and “Mix Window Follows Bank Selection” checked in Pro Tools Prefs>Mixing? Also having “Always Fill Channel Strips When Banking” checked might affect this workflow. I’m not quite sure if what you’re trying to do with Selects Group Tracks is going to get you what you’re desiring here. |
In my workflow I prefer Folders to VCAs, but either way it will spill only those tracks in Artist Mix.
I think that's the only way. Pro Tools Prefs>Mixing are checked I have checked "Always Fill Channel Strips when Banking" But you have given me an idea and I can work much faster scrolling to Folders, I've created a Scroll to track command with a Key input with the name of the folder. Do you know if Eucon Commands can be combined to open a specific folder? I tried: 1. Eucon>track menu>scroll to track 2. Key>name of folder\n (200ms initial delay) 3. Eucon>navigation>folders>toggle folder (500ms initial delay) But in this case if I start while a folder track is select and press the command, it will do steps 1 and 2. But for step 3 it opens the folder where I start the command and not the one selected by the scroll to track command. Thank you very much its2loud for your time.
This does appear to be a bug as the "Scroll to track" is not attention-ing the track in Eucon and the track needs to be attention'd in order to activate the toggle command.
One workaround is the replace the Eucon "toogle folder" command with the key command SHIFT+F. This will toggle the folder for you just the same after scrolling to the track. |
Duplicate Group: Unable to select ID | XJENSEN | Pro Tools 2020 | 2 | 10-29-2020 09:04 AM |
Artsits Control ASSIGN/Select Button: is there that Command in the Eucon List?? | AMIEL | Artist Series | 0 | 02-04-2015 07:52 PM |
Select regions in group | kje | Pro Tools TDM Systems (Mac) | 5 | 11-13-2010 04:21 PM |
Group i/o Select | Keith Moore | Pro Tools TDM Systems (Mac) | 2 | 03-30-2009 11:25 AM |
select regions in group | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-05-2009 06:35 PM |
