No Input from Channels 17-20! Soooo Confused.
Hi Avid Friends!
I have an odd problem. Perhaps you can help me? I'm running 20 Channels from my Audient ID44. I can see all the channel working and show signal via the Audient Mixer App. Happy Days. In ProTools Artist, Channels 1 to 16 work perfectly. It's great! But even though I can select Channels 17 to 20, they show no signal. I can see signal on the Audient Mixer App, but nothing come through to ProTools.... Where has the signal gone? What is stopping ProTools from showing the signal of the final four channels. As far as I'm aware, everything is set up Ok. All the other channels are working. I would LOVE to know if anyone has a fix for this strange strange problem I'm fancying. Thank you all! Adam
Windows 10 Home v21H1 ProTools Artist 2022.4 AMD Ryzen 9 3900X 12-Core Processor 64GB RAM Audient ID44 Audio Interface paired with 2xAudient AS880's to give 20 Channels. |
Re: No Input from Channels 17-20! Soooo Confused.
SiSoftware Sandra
ID Host Name : DESKTOP-4RMP4LU Workgroup : WORKGROUP Computer Model : MSI MS-7C36 Serial Number : To be fille*********** Chassis : MSI Desktop Mainboard : MSI PRESTIGE X570 CREATION (MS-7C36) Serial Number : JA162***** BIOS : AMI (OEM) 1.60 11/06/2019 System Memory Total Memory : 64GB DDR4 Processors Processor : AMD Ryzen 9 3900X 12-Core Processor (4M 12C 24T 4.22GHz, 1GHz IMC, 12x 512kB L2, 4x 16MB L3) Socket/Slot : AM4 (PGA1331) Chipset Memory Controller : AMD F19 (Ryzen3/TR3 Matisse) Host Bridge 10x 100MHz (1GHz), 2x 8GB DDR4 2.13GHz 128-bit Memory Module(s) Memory Module : Corsair/Samsung CMK64GX4M2E3200C16 32GB DIMM DDR4 2Rx8 PC4-25600U DDR4-3200 (15-15-15-37 4-52-17-6) Memory Module : Corsair/Samsung CMK64GX4M2E3200C16 32GB DIMM DDR4 2Rx8 PC4-25600U DDR4-3200 (15-15-15-37 4-52-17-6) Video System Monitor/Panel : Dell Computer DELL S2719DC (2560x1440, 27.0") Video Adapter : NVIDIA GeForce RTX 2070 SUPER (2560S 20C SM6.5 1.6GHz/1.78GHz, 4MB L2, 7.9GB 14GHz/14GHz 256-bit, PCIe 3.0 x16) Graphics Processor CUDA : NVIDIA GeForce RTX 2070 SUPER (2560S 40C SM7.5 1.6GHz/1.78GHz, 4MB L2, 8GB 13.6GHz/14GHz 256-bit) OpenCL : NVIDIA GeForce RTX 2070 SUPER (2560S 40C SM1.2 1.6GHz/1.78GHz, 4MB L2, 8GB 13.6GHz/14GHz 256-bit) D3D 11 : NVIDIA GeForce RTX 2070 SUPER (2560S 20C SM12.1 1.6GHz/1.78GHz, 4MB L2, 7.9GB 13.6GHz/14GHz 256-bit) OpenGL : NVIDIA Corporation GeForce RTX 2070 SUPER/PCIe/SSE2 (8GB) Storage Devices Disk : Seagate ST8000DM004-2CX188 (8TB, SATA600, 3.5", 5425rpm) Disk : Sabrent Rocket 4.0 500GB (500.1GB, PCIe4x4/NVMe) Disk : Sabrent Rocket 4.0 1TB (1TB, PCIe4x4/NVMe) Disk : SANDISK SDDR-409 (USB3) Logical Storage Devices Storage 8TB HD (E:) : 7TB (NTFS, 4kB) @ Seagate ST8000DM004-2CX188 (8TB, SATA600, 3.5", 5425rpm) Recovery : 529MB (NTFS, 4kB) @ Sabrent Rocket 4.0 500GB (500.1GB, PCIe4x4/NVMe) Hard Disk (C:) : 465GB (NTFS, 4kB) @ Sabrent Rocket 4.0 500GB (500.1GB, PCIe4x4/NVMe) Video 1TB SSD (D:) : 931GB (NTFS, 4kB) @ Sabrent Rocket 4.0 1TB (1TB, PCIe4x4/NVMe) Hard Disk : 95MB (FAT32, 1kB) @ Sabrent Rocket 4.0 500GB (500.1GB, PCIe4x4/NVMe) Removable Drive (H:) : N/A @ SANDISK SDDR-409 (USB3) Storage System Storage Pool : Primordial (8.64TB) Peripherals LPC Hub Controller : MSI FCH LPC Bridge Audio Device : Gigabyte TU104 HD Audio Controller Audio Codec : nVidia GeForce 7800 GT Audio Device : MSI F17/19 (Ryzen2/3, TR/2) HD Audio Controller Audio Codec : Realtek Semi 1168 Disk Controller : Phison Electronics Corporation E16 PCIe4 NVMe Controller Disk Controller : Phison Electronics Corporation E16 PCIe4 NVMe Controller Disk Controller : ASMedia Asmedia 106x SATA Controller Disk Controller : AMD FCH SATA Controller [AHCI mode] Disk Controller : AMD FCH SATA Controller [AHCI mode] Disk Controller : MSI FCH SATA Controller [AHCI mode] Disk Controller : MSI FCH SATA Controller [AHCI mode] USB Controller : MSI F19 (Ryzen3/TR3 Starship) USB 3.0 Host Controller USB Controller : AMD F19 (Ryzen3/TR3 Starship) USB 3.0 Host Controller USB Controller : Gigabyte TU104 USB 3.1 Host Controller USB Controller : MSI F19 (Ryzen3/TR3 Starship) USB 3.0 Host Controller SMBus/i2c Controller : AMD SB900 SMBus Printers and Faxes Printer : Microsoft Software Printer Driver (300x300, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Printer : HP OfficeJet Pro 9010 series PCL-3 (300x300, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Biometrics Voice : Analog NUI Voice Virtual Sensor (Voice) Peripherals Network Services Network Adapter : Intel(R) I211 Gigabit Network Connection (Ethernet, 1Gbps) Network Adapter : Marvell AQtion 10Gbit Network Adapter (Ethernet) Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Wireless Adapter : Intel(R) Wi-Fi 6 AX200 160MHz Operating System Windows System : Microsoft Windows 10 Personal 10.0.19043 Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 3 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Might be a clocking issue.
https://support.audient.com/hc/en-us...-Digital-Setup Or a driver issue. Do you have the latest driver installed? If both of those check out then try deleting all inputs in Pro Tools and start fresh. It’s hard to read your screen grabs. The resolution is too low or DUC has downgraded the pics. |
@its2loud
Clocking is good. Firmware is up to date. Just tried creating a new project and starting again. I'm encountering the same problem. The Audient Mixer is seeing everything as it should. ProTools recognises Channels 17 to 20, yet there's no signal.
I suggested the windows driver, not firmware. I suggested clearing the I/O in Pro Tools, not creating a new project. I just realized you’re on Pro Tools Artist. This version is limited to only 16 inputs. It will show more in the I/O but only 16 are available to you. Pro Tools Artist The newest addition to the Pro Tools product line allows the next generation of content creators, artists, and music producers to produce amazing material without feeling overwhelmed, or breaking the bank. Priced at $99 per year (or $9.99 per month), this version of Pro Tools is full "forward-compatible" and allows you to take your projects to larger studios using more advanced versions of the software. Some of the key features include: 32 Audio Tracks 16 simultaneous Audio Inputs 32 Instrument Tracks Artist Bundle PlugIns New GrooveCell, and SynthCell Virtual Instruments Melodyne Essential PlugIn Support for Core Audio, ASIO, and WASAPI-compatible Audio Interface |
Opps. Sorry.
Yes. Ahhhhhhhhhh. Thank you. How. Freaking. Annoying. Problem solved then! Thank you for your help. :)
1 input to 2 channels | HVF | VENUE Live Sound Systems | 3 | 02-13-2017 01:13 PM |
Confused by input latency in Pro Tools | hollow | Windows | 11 | 02-12-2014 10:59 AM |
PT 9.02 USB Input Setup -- Very Confused! | snapperglubb | macOS | 1 | 11-19-2011 09:14 PM |
confused using 11R mic input with Logic 9 | jezzbo | Eleven Rack | 8 | 10-16-2011 12:06 AM |
More Input channels | José Luis Díaz | Pro Tools M-Powered (Mac) | 2 | 01-09-2007 03:06 PM |
