Old 09-18-2023, 02:38 PM
bernstudios bernstudios is offline
Default update from 12.6 to 12.6.9
I was wondering if I should upgrade from 12.6. to 12.6.9 (latest Monterey) because my system became pretty unstable with newer apps lately - and if yes would you recommend to just do it over the existing 12.6 and protools 2022.12?
Old 09-18-2023, 02:58 PM
Default Re: update from 12.6 to 12.6.9
Not much info here for folks to make useful suggestions from.
What will likely help you get better help -
What apps became unstable? Pro Tools became unstable? What exact errors/problems do you see for what app?
What was changed before things became unstable.
What exact Mac/config? esp Apple Silicon or Intel?
If Pro Tools you likely should start by running though the standard troubleshooting steps before making any changes. See under "Help Us Help You" up the top of each DUC web page.
Old 09-18-2023, 03:59 PM
off the wall's Avatar
I'm not aware of any application stability issues with 12.6 vs 12.6.9 but I've had no issues running 12.6.x updates regularly with PT. The incremental updates are usually for security holes found in the OS.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.8.0, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7
Pro Tools Ultimate 2023.9/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Old 09-28-2023, 02:06 PM
ok if it`s only for security reasons I don`t have to update - I thought stability issues were getting better along the updates too
Update Module Firmware message after 3.7 update WildHoney Avid S4/S6 1 10-21-2017 11:28 AM
Sierra 10.10.6 - To COMBO update - or App Store Update ? Seafoam_Green macOS 4 09-15-2017 01:19 PM
10.3 Update - Windows shutdown issue has returned. Update at your own risk. crm0510 Windows 14 09-19-2012 01:50 PM
10.5.6 update. Is it safe to apply the system update from 10.5.5? SBCCMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2009 02:27 AM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
