Old 02-10-2003, 09:09 PM
efernan1 efernan1 is offline
Default ASIO driver, 001 & WaveLab
Any update about a working ASIO driver/setup for WaveLab using a 001 card?
Thanks!
Old 02-11-2003, 08:12 PM
Default Re: ASIO driver, 001 & WaveLab
bump
Old 02-12-2003, 08:54 AM
DaveJDoc DaveJDoc is offline
Also ASIO driver and WaveLab using an Audiomedia 3 card?
Any news please.
Dave
Old 02-12-2003, 07:33 PM
Hi again,
Yes, the problem seems to be with the Digidesign ASIO driver in general. I only heard that the only Digi hardware working with Digi ASIO drivers and WaveLab is the MBox, nothing else works. In the other hand, Cubase SX/Nuendo seems to work just fine.
Still waiting for some update.
Thanks!
Old 02-13-2003, 07:02 AM
JayBones JayBones is offline
I had the same problem with Wavelab 4.0g (the latest update on the steinberg site). I could not open the ASIO control panel and could not set the driver to Digi ASIO. I tried re-installing Wavelab 4.0 from the original CD (the version before any updates) and now it works. It will use the Digi ASIO driver but still no ASIO control panel to change any settings. I have no idea why it worked but it did.
I'll try the Wavelab update again after the new ASIO driver is ready.
Old 02-13-2003, 05:35 PM
So, older versions (4.0x) of WaveLab works? Any other could confirm this?
Thanks!
ASIO Driver for WAVELAB??? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2008 01:03 PM
MBox, Wavelab 4.01 and ASIO Driver Problem GroovehouseRS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-17-2005 12:56 PM
An ASIO Driver that works with Wavelab PedMar Pro Tools TDM Systems (Win) 5 03-30-2004 11:17 AM
001 ASIO Driver and Wavelab DaveJDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2003 09:10 AM
Digi001 with ASIO driver on Wavelab 4 Nahvegador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-23-2003 12:14 AM
