Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 09-22-2021, 08:22 AM
hannahjazzz hannahjazzz is offline
Default Can I use a vox preamp as an interface
I have an Avalon mic preamp that I want to
Use for the 96k A/D converters to transfer my stereo mixes from studer 1/4 inch tape to digital to master.
I have other interfaces, but no
Other 96k I don’t think.
Am I able to use the Avalon as an interface or will this create problems? Or alternatively, if I use my digi 003, will the 48 A/D not suffice for tape transfer for mastering through software?
Thanks
H
Old 09-22-2021, 08:26 AM
Sardi Sardi is offline
Default Re: Can I use a vox preamp as an interface
Avalon doesn’t make audio interfaces, so no, you can not.
Old 09-22-2021, 08:38 AM
I'm not exactly clear on what you need, so here is some general info re the 003. The SPDIF IO can operate at up to 96K. This might allow you to run the Avalon thru high-end converters at 96K to feed the 003 SPDIF input. You can also connect the Avalon analog output to one of the TRS line inputs of the 003. This allows you to record thru the Avalon into a 96K session(or lower sample rates). The 003 converters are adequate and you will still get the flavor of the Avalon. Personally, I see no reason to record at 96K and have had many commercial releases at 48K with happy clients
BTW, probably best to refer to it as a vocal preamp as most of us think of guitar amplifiers when someone mentions Vox
Connecting preamp to compressors to interface ToneSetter General Discussion 12 03-08-2020 07:11 PM
8 channel audio interface and stand alone preamp alidav macOS 18 03-15-2014 09:32 AM
Which interface/preamp would you recommend? Judicious Pro Tools 9 11 06-02-2011 11:48 PM
Using outboard Preamp/Bypassing Mbox2 Preamp KennyC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-10-2007 01:00 PM
I'm torn.. Digi001 with better preamp or Digi002 with cheaper preamp/future upgrade Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-06-2003 12:22 AM
