Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-02-2021, 12:11 PM
josoro505's Avatar
josoro505 josoro505 is offline
Default Combining Monos into Stereo
I see there is a way to split a stereo track into 2 mono tracks, is the reverse possible?
OMEN by HP Laptop 15-dc1xxx
Intel core: i7-9750H-CPU 2.60GHz 6 Cores, 12 Logical Processors
NVIDIA GeForce GTX 1650 Version 451.67
RAM: 32Gb (31.8 usable)
Windows 10 Home x64
Running PT 2020.9.1
Old 05-02-2021, 12:24 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Combining Monos into Stereo
If you have a L track and a R track in two mono tracks, just move them next to each others, then create a stereo track, choose both mono tracks and drop them into stereo track.
Janne
Old 05-02-2021, 12:29 PM
josoro505's Avatar
Thank you for such a timely response!!
Another issue:
I solo a track and move the cursor about the timeline; sometimes the audio is heard, sometimes not--even though I can see the levels moving. When I play the same track together with the others, the unheard audio is heard.
This seems quite strange. Any ideas?
Windows 10 Home x64
Running PT 2020.9.1
Old 05-02-2021, 01:11 PM
JFreak's Avatar
You may have solo safe on some of the tracks
Janne
Old 05-02-2021, 02:09 PM
Another issue:
This sounds like a routing problem(if you solo a track that routes thru an AUX track, the AUX track will mute when you solo the original track. Solo-safe the AUX track to solve). Back to the original questions:
1-any stereo audio track can be split to 2xMono tracks by right-click on the track name and select Split to Mono.(you would then delete or hide/make inactive the original stereo track)
2-as for combining 2 mono tracks into a single stereo, Janne hit that on the head, but my 2 cents is; why bother. I would simply make a group of the 2 and treat them as a stereo track without bothering to actually put them together(which doesn't offer a significant advantage that I can see)
Old 05-02-2021, 03:48 PM
JFreak's Avatar
Depends what you want to do with the stereo image. Sometimes it is just easier to have it as a stereo track and insert a stereo plugin, or sometimes it is easier to send two mono tracks to stereo aux ane process there.. also automation is different in the two scenarios
Janne
Combining Regions adam79 Tips & Tricks 2 10-29-2016 12:51 PM
Dual Monos from OMF not Recording? brianbobcat Post - Surround - Video 4 03-22-2013 04:14 AM
Separate a stereo track into two monos Anangu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-18-2009 01:38 PM
Combining Regions GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-06-2005 11:58 PM
combining tracks? Nicc24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-02-2005 04:28 PM
