Old 05-07-2000, 03:04 PM
uno1234 uno1234 is offline
Default Focusrite Red 3
The Focusrite Red 3 gets very hot. It is separated on either side by half a rack space (it's an SKB case), and above it is a Red 8, below it is an L2 (which generates heat to the sides, not the top).
Has anyone had any problems with these units overheating if they are too close together? The Avalon 737s overheated twice, so I'm trying to be careful.
Thanks in advance.
Old 05-09-2000, 07:26 AM
BDWillis BDWillis is offline
Default Re: Focusrite Red 3
They do simmer, but we've had one in a rack for three years with only trouble being a blown fuse… doubt it was heat related. Just allow a bit of space top & bottom as you are. If it (or other gear) is running too hot, try 220~240V whisper fans, running off of 110, mounted in the back of the rack or closer if needed. Extremely quiet, and move just enough air to keep tubes & Class A stuff ventilated! Good luck…
Warmest Regards,
Brian
Focusrite ISA-428 Mk 1 albee1952 Buy & Sell 5 01-02-2014 03:19 PM
Focusrite and 002 jamesimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2012 10:13 AM
Focusrite d2/d3 shareec70 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-19-2009 12:32 PM
focusrite D2 rageagainst Pro Tools TDM Systems (Mac) 6 07-27-2004 02:59 PM
Focusrite 1.9 ? Fortran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-10-2003 06:38 AM
