Multiple SPDIF inputs...?
I have a problem.
I need to connect several stereo digital outputs (laptop, other computer, Apogee Mini-me) to my main DAW computer. Even if I get Pro Tools with ADAT (like a 003), the question would be the same. How to I connect several stereo pairs of SPDIF to an 8 channel AES/EBU? What kind of converters are there for that? PS: what about connecting them all to an SPDIF in only (like with a switch box to select which output is being used)? |
Re: Multiple SPDIF inputs...?
ADAT, while optical, is NOT s/pdif protocol.
The switcher would work. Check out Z systems for a spdif switcher. Not cheap.... |
Why not cheap? It's just a stupid box to select an SPDIF input... WTF OK I checked it out, it's WAAYYY too overkill for this application. So what are my options? Just use analog inputs? my laptop has noisy line out, the mini-me needs to sync through spdif, and it's the only converter I have. This gets more and more ridiculous everyday. Didn't they invent SPDIF 20 years ago to avoid signal deterioration? And now I'm back to 0? How come when it's analog, any cheap mixer will do, but if I want to connect several digitals, there's a huge issue? lol |
I have a Digital Detangler with 4 aes/4 spdif that I'm not using anymore......
Given what you listed, I would patch the Mini-Me to the 003 SPDIF connections. The laptop: I would run a mini TRS to dual mono quarter inch and patch into the AUX inputs of the 003(hit the Aux to Mon button to hear the laptop). Any other digital device will need another path. If you get a Presonus Central Station(which I use) it has optical and RAC SPDIF inputs. I feed RCA from my 003(in case I want to skip the 003 D>A) and I run optical from my computer so I can monitor all computer audio(handy for mastering in Wavelab or listening to iTunes).
How to get SPDIF inputs working? | roubignolle | Pro Tools M-Powered (Mac) | 0 | 01-05-2010 09:59 AM |
Pre-Amp / AD for my SPDIF inputs on Digi003 | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-08-2009 01:32 AM |
spdif inputs? | henryglover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-07-2007 07:10 PM |
Can you add more spdif inputs and outputs to 002? | Sherbert99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-12-2006 02:51 PM |
SPDIF inputs gone in 16 bit session! | ongaku | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-06-2001 06:11 AM |
