Old 04-09-2017, 09:13 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Comparing 12.4, 12.6.1 and 12.7.1 on Windows 10 X99 systems
Hi guys,
What are your findings when you compare these 3 versions? Especially Windows users? I tried 12.6.1 and went back to 12.4. 12.7 didn't work well for me. I also installed 12,7.1 for a mix, and it worked quite well. I went back to 12.4 when I read a post about the return of midi delay in 12.7.1. I didn't actually test that; there was no time to fumble around with bad midi. I had work to do, so I just went back to 12.4, which seems smooth enough, though I still get lots of CPU peaks, and many situations where PT halts on a white screen with a spinning ball. Does this also happen on the later versions?
Some people will swear that 12.7.1 is the best, but I know PT doesn't like midi and VI loads. It only works very well in purely audio situations, so it's all very subjective.
Has any serious midi / VI user tried 12.7.1 extensively? Has anyone had the time to compare these 3 versions? Any insight would be welcome. Thanks.
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.12 | Windows 10 Pro
Old 04-09-2017, 09:31 AM
TOM@METRO's Avatar
Default Re: 12.4, 12.6.1 and 12.7.1
Different systems and different workflows dictate different results. There seems not to be a "one size fits" all answer on this subject.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-09-2017, 09:35 AM
lesbrunn's Avatar
Your'e right, Tom. That makes it very difficult. Maybe I should narrow it down to Windows 10 X99 users? But I should think midi and VI problems would be similar across a wider section?
Old 04-09-2017, 09:42 AM
lesbrunn's Avatar
Default Re: Comparing 12.4, 12.6.1 and 12.7.1 on Windows 10 X99 systems
Originally Posted by lesbrunn View Post
Hi guys,
After Tom's post, I edited the title to narrow things down a little. Another thing is that I'm more interested in production workflows with extensive MIDI and VI usage.
Anyone?
Old 04-09-2017, 10:27 AM
ejinbc ejinbc is offline
Mods
I think there may be an echo in here. I recently posted this...
There have been so many problematic releases lately that it might be useful to have a sticky specifically for vetting new releases (user-based beta testing) AND voting ?? on the best / least problematic current release.
Too many uninstalls lately. Let's see, 12.4 to 12.5, back to 12.4, then 12.5.1, back to 12.4, then 12.6, back to 12.4, then 12.6.1, then 12.7, back to 12.6.1, recent "noise blast" in 12.6.1, back to 12.4 ...
Or is there a least problematic release ? It appears that most of the Mods think that 12.4 is the most stable release. The Avid Rep suggested only updating versions if a specific feature you require has been added .
So, right now, for me, 12.4 on Win 10 seems to be the most stable, although I need to adjust the processor affinity to record at low buffer settings.
E
Assu P8Z77 MB, 3770K CPU O/C @ 4.5 GHz, 16 GB RAM, 512 GB SSD, 2 TB Data drive, Gigabyte 950 video card running HDMI 2.0 @ 4K resolution, all USB peripherals plugged into USB3 ports EXCEPT Motu 1248 which is plugged into rear USB2 port, Turbo Mode Off in BIOS, C-states Off in BIOS, WiFi Off in BIOS, BT Off in BIOS, On-board sound Off in BIOS, HPET Off in BIOS. Command 8, Roland TD6, Edirol PCR M80, Korg SP250. Windows 10 (all other standard DAW optimizations), Pro Tools 12.4, Waves Gold Bundle, Waves HEQ, Native Instruments Komplete 10.
Typical Recording Session 24 bit @ 96 kHz, Processor Affinity 6 of 8, 64 sample buffer, 16 Audio Tracks, 8 multi-channel Aux VI Tracks, 16 MIDI Tracks, 4 HEQ instances, 1 HDelay instance.
Old 04-09-2017, 04:15 PM
lesbrunn's Avatar
Originally Posted by ejinbc View Post
Mods
E
Hi ejinbc,
Thanks for your reply. I also use 12.4 with processor affinity adjustment. Do you get the white screen/spinning ball thing? I've had to reinstall PT a couple of times because of this. It seems very random to me, and all sorts of simple little things seem to cause it. I haven't been able to put a finger on it up till now.
Old 04-10-2017, 12:18 AM
mandal mandal is offline
My feeling is that Pro Tools HD 12.7.1 is a stabile version for Win 10 computers...but I'm not not using a lot of midi's so...
Avid OMNI PCIe
Pro Tools Ultimate 2021.6
Avid HEAT
Dell 43" 4K LED P4317Q
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
Cooler: Be quiet! Dark Rock PRO 4
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Cabinet: Fractal Design Define 7 XL Black
Disk1: Samsung 970 PRO 1TB M.2 SSD
Disk2: Samsung 840 PRO SSD
Disk3: Samsung 860 EVO SSD
Power: Corsair RM750x, 750W PSU
Microsoft Windows 10 Home 64-bit OEM DVD
Old 04-10-2017, 12:25 AM
lesbrunn's Avatar
Thanks mandal,
I checked it out on some purely audio work without any VI's, and it was
pretty smooth. My problem is midi!
Old 04-10-2017, 08:29 AM
YYR123's Avatar
YYR123 YYR123 is offline
Is there a verifiable many issue with 12. 7.1?
Or were they are just rumors that there was a midi issue with that release?
I'm curious myself because I'm thinking about jumping,
Daniel
Old 04-10-2017, 09:16 AM
Southsidemusic's Avatar
Jumping where !? Washington Bridge Parachute Jumping ? Jumping Jack Flash
Sorry, couldn't resist
Whatever you do 12.7.1 IS stable and we can work on that version just as easy as on 12.4
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
