Old 04-26-2017, 04:28 AM
algroves algroves is offline
Default HDX 12.7.1 forgetting delay compensation
I'm having issues with 12.7.1 on OS 10.12.2 where the delay compensation is periodically falling out of line. The workaround is to open Playback Engine settings and select a different buffer setting - doing this seems to force PT to recalculate and things are back in line.
Does anybody else experience this issue?
Old 04-26-2017, 04:43 AM
Stig Eliassen's Avatar
Default Re: HDX 12.7.1 forgetting delay compensation
I assume this is OS 10.12.2? Are all plugins up to date?
Old 04-26-2017, 04:44 AM
Yes sorry, 10.12.2.
All plugins are up to date - system was only put together last month and all plugins/installers downloaded from the manufacturers website as they were being installed.
Old 04-26-2017, 04:58 AM
syMPh syMPh is offline
same here.. it seems to be triggered by when I get a -9173 error from cpu hitting a periodic spike it can get out of whack... it seems a feature of later releases unfortunately... very easy to catch if you're doing parallel stems out but I would guess some people don't notice it as much especially those that mix purely itb and are not using a great deal of live parallel auxes with inserts etc. I do the buffer thing too when it happens.
System Details
Old 04-26-2017, 05:00 AM
That's interesting that you find it occurs after a -9173. The difficulty is if you don't catch it, you can end up printing a mix with compensation errors without realising.
This is frankly abysmal from Avid, and is one of a long list of issues I have had since upgrading last month.
Can you post a screenshot (hosted elsewhere) of plugins and routing? Does this happen in all sessions?
Old 04-26-2017, 05:03 AM
Image of the current session I have had problems with. I haven't noticed a pattern to which sessions it manifests in, but it has been happening to a number of them.
Old 04-26-2017, 05:10 AM
Southsidemusic's Avatar
You need to repost that picture as it just shows a square box without content.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-26-2017, 05:15 AM
Old 04-26-2017, 07:12 AM
Hard to tell since most of the I/Os are named "PRINT". You do realize that input monitoring bypasses ADC (cmp value goes to zero)? You can force-enable ADC on those by Ctrl+Cmd+clicking the cmp section.
Besides Echoboy, I don't use those plugins. ADC in 12.7.1 has been stable for me.
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 04:35 PM
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 08:54 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 12:10 PM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-06-2010 12:00 AM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 09:59 PM
