Old 12-12-2005, 07:56 PM
durden212 durden212 is offline
Default audio midi setup with digi002 and 103
if someone could please help me with my audio/midi setup it would be GREATLY appreciated.
i'm using digi002 with OSX 10.3.9, and i'm running protools 6.4 -- i'm trying to setup my midi controller, yamaha s90, to operate with the digi002 to control reason. when i go into my audio/midi setup, the digi002 doesn't have any midi ports. i hit rescan midi several times, but it doesn't register.
the next step i took was clicking on the update midi i/o in the digidesign folder, and it gives me a message that no MIDI I/O interfaces are detected. the unit is turned on, and works fine with protools and iTunes as far as audio goes. i have my midi controller connected via a midi cable to the digi002, and the MIDI in light is solid green on the 002 indicating it is recognizing the midi signal from the keyboard.
is this a firmware problem? do i need to upgrade to 10.4 to use the midi interface? if anyone has any suggestions i would really appreciate some help! thank you!
Old 12-12-2005, 08:26 PM
Slim Shady Slim Shady is offline
Default Re: audio midi setup with digi002 and 103
Did you download & install Quicktime 7 per chance? If you use software update, it probably installed along with 10.3.9. There are known issues with QT7 and 10.3.x w/PT - if you search through old threads you should find the instructions on how to revert to QT6.
Old 12-12-2005, 10:19 PM
thanks for the suggestion. i actually already trashed qt 7 and the rest of the quicktime folders, but still i'm getting nothing from the digi002. the strange thing is that when i connect the controller via USB directly to the back of the mac, audio midi setup recognizes it immediately, but it won't see the digi002 as a midi interface.
i've seen a couple other posts similar to this one on the forum, but i haven't found any answers yet. if anyone has had a similar problem and figured out a solution, please let me know so i can avoid throwing the piece out the window into the snow. thanks.
Multiple MBox Pro Instances/Icons in Audio MIDI Setup -> MIDI Studio lpeckham macOS 8 04-24-2014 07:39 AM
Audio MIDI Setup: Digidesign Audio Drop-down Item Disappears TonyPT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-15-2007 06:43 AM
Oops, Deleted 002R MIDI in Audio MIDI Setup! fader8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-06-2007 06:43 PM
Need Help!!! Midi setup for Digi002 and Yamaha ES6 BlasDON 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-19-2005 07:28 PM
Need help with midi setup on Digi002 PT 6.1.1 Icemaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-11-2004 06:56 PM
