Old 08-08-2022, 01:37 PM
Cayce Cayce is offline
Default Freeze Routing Folder & Contents
I'm working on a fairly complex arrangement that has several routing folders with many member tracks, and occasionally another nested folder. I'm getting CPU overloads and would like to freeze some of these routing folders that aren't being worked on at the moment. What's the most efficient way to go about that? I know the routing folder is pretty much just an aux track, but is there a way to freeze that folder and all its members at once?
Another question would be, if I set the folder and all its contents to "inactive", does that exempt it from CPU drainage?
Thanks.
Pro Tools Studio, 2022.5.0
iMac (Retina 5K, 27-inch, Late 2015), Monterey 12.4
4 GHz Intel Core i7
2TB Internal SSD
32 GB 1867 MHz DDR3
3 External Monitors: 27", 24" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 08-08-2022, 07:50 PM
Default Re: Freeze Routing Folder & Contents
Thanks.
Anything that is inactive(tracks, or plugins) will/should use zero system resources. Personally, I would lean more to freezing track, but leave the folder tracks alone. Having said that, I would also be careful with track freeze and keep things frozen ONLY as long as the files stay on your computer. If the session is to be opened on another system, unfreeze everything before the move. Just to be totally on the safe side, I would save a copy of the session(with media/audio files), just in case(you'll never regret doing this, but you might regret not doing it). My preference would be to commit whenever possible, over the freeze option
Old 08-08-2022, 09:25 PM
s.d. finley s.d. finley is offline
I will also suggest Commit over Freeze. You can commit the bus that all the tracks are routed too. In the Commit dialogue box check hide and make inactive to the original tracks and bus. You can reactivate them later to edit if needed.
sdf
www.sugarhillstudios713.com
Old 08-12-2022, 09:08 AM
Thanks to everyone for all of this. Great suggestions, and helped me avoid those pesky "CPU" alerts.
4 GHz Intel Core i7
2TB Internal SSD
32 GB 1867 MHz DDR3
Old 08-12-2022, 09:11 AM
Thanks, Albee... always good to get your input... I've put all these suggestions to use, running a lot more smoothly now... liking the "Commit" suggestion a lot.
4 GHz Intel Core i7
2TB Internal SSD
32 GB 1867 MHz DDR3
Old 08-12-2022, 02:40 PM
Cool! Curious as to what is more popular; Commit the entire track(with or without automation), or Commit Up To This Plugin. I tend to commit up to certain plugins(about 98% of the time) for mixing. Archiving can be a different animal
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
"Obtaining folder contents" task Bydy Pro Tools 12 1 01-26-2021 02:14 PM
Freezing A Folder Track Does Not Freeze Its Contents lesbrunn Pro Tools 2020 37 05-08-2020 08:05 AM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
Calculating Waveforms and Synchronizing Folder Contents randomly BrianJArmstrong macOS 7 01-27-2019 08:07 AM
