Old 05-10-2021, 04:40 AM
madiface madiface is offline
Default Avid S3 Touch-sensitive fader lock?
Hi all,
Apologies if this has already been posted elsewhere in this forum, but I couldn't find it in search.
I've just recently moved from a set of Artist Mixes to the S3. I'm so used to working on digital mixing desks that only register fader input when touched by something conductive (ie. my finger), otherwise the fader pings back to where it was. The Artist Mix does this, as does the SSL Nucelus and pretty much every other intelligent touch-sensitive controller.
However the S3 doesn't - is there a setting somewhere to enable it? I plonk scores on top of my surface and it changes the mix...!
Thanks for any help.
Old 05-11-2021, 03:54 PM
EddieJones's Avatar
Default Re: Avid S3 Touch-sensitive fader lock?
Are you sure the Artist Mixes behaved differently? If it were the case that the faders sprang back, then the motors would be permanently on, trying to get back to position and burn out. I just checked my S1 and Dock and they don't spring back either unless there's automation and they do then. I checking with PT what DAW are you using?
Avid Artist Mix Replacement touch-sensitive rotary encoders kuaise Artist Series 44 10-29-2022 10:52 AM
Control|24 touch-sensitive faders MacAlien ProControl, Control|24, Command|8 1 11-30-2016 07:50 AM
Are the rotary encoders touch-sensitive... Stig Eliassen ICON & C|24 2 07-31-2008 08:53 AM
touch sensitive faders CharlieAoun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-10-2003 06:22 AM
Difference between motion sensitive and touch sensitive faders? bp78 Pro Tools TDM Systems (Mac) 7 07-03-2002 09:27 AM
