Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #21
Old 02-01-2021, 11:33 AM
studiosus studiosus is offline
Default Re: Need advice on a good way to quantize live drums w/wo plugins
Hi there,
I followed eric valentines youtube channel lately, he shares tons of highly interresting stuff (at least for me). This was on it there too:
https://youtu.be/QISP11wf1iw
I hope it΄s fine, to post it here. Not quite what you΄re looking for, but a very detailed explanation of beat detective among other even more useful ideas.
  #22
Old 02-01-2021, 11:42 PM
Southsidemusic's Avatar
Originally Posted by studiosus View Post
Hi there,
Great
Thanks for posting. Very good video!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #23
Old 02-01-2021, 11:44 PM
Originally Posted by EGS View Post
Try my "loose" 4-bar TCE idea above!!!
Am trying and I am surprised it works soo good and not hard, a bit of fiddling but worth it. Many Thanks
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #24
Old 04-25-2021, 08:09 PM
Rader Ranch Rader Ranch is offline
Originally Posted by Sardi View Post
You’ve pretty much described a manual Beat Detective process.
The problem being that after going back and fixing the inevitable hundreds of bad edits and fades beat detective creates you eventually learn that doing it manually is much less painful. I wasted far too much time (years ago now) trying to make BD work...it couldn't understand anything but the simplest 4/4 beats and still borked the edits on those far too often. "Groove template extraction" could never correctly identify anything. Identifying bars manually and figuring yourself what really needs adjusted is so much better. You can retain the human fluctuations in tempo etc and just fix to whatever is your standard. The person you responded to was fortunate to just do it manually from the get go.
Of course if you want to export the resulting tempo map correctly into Logic, forget it. Tried many times/methods over the years including today (why I went searching for threads like this ). From Logic to PT possible, but not the reverse.
I've never heard any TCE algorithm that had an acceptable lack of artifacts.
  #25
Old 04-26-2021, 08:08 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by Rader Ranch View Post
... I've never heard any TCE algorithm that had an acceptable lack of artifacts.
I use Waves SoundShifter. When TCE'ing by tiny amounts, it sounds acceptable to me. Large amounts of TCE adjustments will produce artifacts, however.
Click for audio/video demo
Click for resume
Matching sampled drums volume to live drums? any automated way to generate automation Atlanta Bliss Tips & Tricks 14 05-12-2015 12:59 PM
Easiest way to quantize/Build a tempo map from drums not to a click? brandobean Tips & Tricks 5 02-15-2012 05:29 AM
Advice on Separation and Quantize CottersJ Pro Tools 9 8 02-24-2011 04:59 PM
A Good Guide/Tips to Quantize / snap to beat wave pattern. Matt Darcy General Discussion 6 08-12-2008 05:29 AM
Advice for recording live drums w/Digi001 Rober50 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2006 06:14 PM
