import audio WITHOUT sample rate converting?
let's say i WANTED to import a 44.1 audio file into a 48 session and i did NOT want it to be converted to 44.1
is there a way in PTLE? thanks |
Re: import audio WITHOUT sample rate converting?
I don't believe so.
If somehow you managed to get the file in there, it'd play back too fast. A 48KHz session will read 48 thousand samples per second, so in the first second of playback it'll read 44,100 samples (all of the first second of music) of your 44.1KHz file and then read another 3900 samples (a little bit of the next second of music).
Macbook Pro 2.4 GHz, OSX 10.5.5, PTLE 8 + MPT, 003R Factory, Apogee Mini-Me |
that's kind of the idea
It's easy. Import audio menu, import the audio, and untick sample rate convert. Pro Tools will ask you if you really want to do that, and if you click yes, than it will import it at the original sample rate.
Tamas Dragon
my blog:Tamas Dragon |
thanks!
I'll give it a go |
Import Audio - Sample Rate Confusion | nhaudio | Pro Tools TDM Systems (Mac) | 1 | 07-23-2010 07:47 AM |
Select sample rate of audio to import -V7? | Karl Engel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-05-2010 10:59 AM |
Converting audio into PT, which sample rate? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2005 10:37 AM |
Sample rate conversion using import Audio | gtole | Pro Tools TDM Systems (Mac) | 9 | 03-17-2003 08:14 AM |
Audio import sample rate conversion | P Oskam | Tips & Tricks | 0 | 12-03-2001 07:52 AM |
