#121
I have been experiencing constant -9093 errors. Trashing preferences worked for a couple days and, although it was annoying, it worked.
Now that isn't working. Mac Studio HDN in chassis - driver updated Ventura
Apple M1 Mac Studio (base model) ProTools Carbon w/SSL XLogic MADI-AX Instagram: https://www.instagram.com/sparkletune/ |
#122
I'm depressed
Pro Tools closes after loading plugins I actually formatted my Mac without time backup and still so yeah, 2023.3 made a very bad first impression for me
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
#123
Are you saying that you should, or I should? I've already ventured into his Symphony/Stratus world, primarily so I have a chance of loading old sessions which used EA plugins (the migration isn't easy but it can be done). If you haven't already grabbed Symphony/Stratus you definitely should. Or maybe you were referring to the surround versions. And I agree that they're a fantastic swan song from Michael.
#124
I have the normal versions, only problem is they are not AAX Apple Silicon native yet. Just sayin' if it is time to forget lexicon altogether and buy the 3D versions which are latest and greatest from MC.
#125
2023.3 is a no-go here. It won't load many plugins, especially virtual synths. I've tried all of the usual measures and tricks (delete prefs, reinstall, take out half the plugins from their folder, launch, put them back). Rolling back to 2022.12 made them show up and work regularly again.
Pro Tools Studio on a MacBook Pro M1 Max 32GB RAM Monterey 12.6.2.
Marco Marinangeli Magelic Productions, Inc. Compression Records http://www.compressionrecords.com |
#126
2023.3 works wonderfully here on latest Ventura. All plugins updated.
#127
![]() Quote:
A bunch of your plugins are clearly not AS native. Tick the box to run Pro Tools under Rosetta. Don’t roll back to the prior version. Sent from my iPhone using Tapatalk |
#128
![]() Quote:
Well Pro Tools 2022.12 was the first version that could run natively on Apple Silicon processors, however it loads with Rosetta2 by default. When opened with Rosetta2, Pro Tools scans all your x64 (Intel) coded plugins. With the launch of Pro Tools 2023.3 , Pro Tools opens as Silicon native app, and it won't scan / can't use Intel coded x64 plugins. If you still have a lot of intel-coded plugins, go to your Mac's App folder, right click on the Pro Tools app, click 'show info' and check the 'Open with Rosetta' box. Also, Pete Gates made a nice app that checks if your AAX plugins are still x64, or universal binaries (Universal binaries will run both as x64 when pro tools launches with Rosetta, or as arm64 when Pro Tools launches as silicon native app) https://petegates.com/pgptprefs.html Perhaps a lot of your plugins have updates available, most of the AAX plugins are available as universal binaries already. Check AVID's database which is frequently updated with AAX silicon native available plugins: https://avid.secure.force.com/pkb/ar...-Compatibility However, some third party developers are not ready yet with AAX silicon native versions of their plugins. If you are dependent on those, run Pro Tools with Rosetta2
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Universal Audio Apollo X4 & 2 Octo Sattelites | Pro Tools Ultimate 2023.3 | macOS 13.2 |
#129
And with that revision I lost the use of my Command8.
It's a pity since was still working fine. I will have to buy the SSL UF8 then.
Max Carola Recording Engineer - Mixer - Producer - Composer www.maxcarola.com Pro Tools Ultimate 2023.6.0 - Monterey MacBook M1Pro 10-16GB Dangerous Music Summing - Focusrite Dante Rednet2 - Amek/Neve, Focusrite, TC Electronics, Mytek DA, Apogee ADDA |
#130
![]() Quote:
One of those occasions when feeling like a fool is perfectly fine... Many thanks! It worked, of course!
What’s due in 2023? | noiseboyuk | Pro Tools | 57 | 07-06-2023 05:01 PM |
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
2023 Apple Silicon and Pro Tools | Chevron | Pro Tools | 59 | 03-21-2023 07:54 AM |
32 Channel - Apple Silicon - Pro Tools Rig in 2023 ? | T-Low | Pro Tools HDX & HD Native Systems (Mac) | 25 | 01-02-2023 09:30 PM |
