Old 04-02-2010, 09:54 AM
sbaitso sbaitso is offline
Default 003 Rack Randomly Powers Off, Won't Turn Back On
Today my 003 Rack randomly clicked off and would not power back on.
Immediately trying to power it on again failed (it will go through one click of the 3 or 4 power on startup clicks then stop).
After a few minutes of being shut down, it will power up sucessfully, but after a few minutes, it shuts down again. All cables, including firewire (and excluding the power cable, of course), have been removed from the back of the unit, but the issue still exists. Has my unit failed?
I've searched around here and on the Digidesign site, but have yet to find any info related to this issue. Has anyone experienced this before?
Old 04-02-2010, 10:18 AM
Default Re: 003 Rack Randomly Powers Off, Won't Turn Back On
Sounds like a heat related failure of some component inside(most likely on the power supply). I would get on the phone to tech support and see if you have a warranty issue. Meanwhile, is it in a rack with other gear packed tight on top and bottom of it? Can you give it some air space above and below to help cool it? Do you have a small fan you could point at the back to see if that helps?
Old 04-03-2010, 07:47 PM
Quick update... after about in hour, it powered on and stayed on for long enough to finish a session. It did shut down once in the middle of that session, though. As of today, its been working in short bursts, but it eventually clicks off. I did move some things around in my rack just in case it was an overheating issue, but given that the issue is still occurring, I fear its a hardware failure. Its been stable for the two years of use until yesterday.
Thanks!
Video randomly stops playing back rnd Pro Tools TDM Systems (Mac) 0 08-23-2011 11:34 AM
How to turn BACK ON Number Pad shortcuts? toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-15-2009 07:32 PM
MBox Shuts off Randomly and Feeds Back thespacebandito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2008 05:17 PM
2.3 GHZ G5--ProTools 7.3 Randomly Powers Off nathanlewan Pro Tools TDM Systems (Mac) 14 07-21-2007 09:42 AM
anyone know how to turn spotless back off? samuelowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2005 06:45 AM
