Old 11-09-2012, 02:15 AM
DaleB DaleB is offline
Default Distortion
Tonight, I momentarily switched from my Digi 002 to a Presonus StudioLive. (I wanted to test it with my D-Command.) The monitoring didn't seem to work at first, and I had work to do, so I switched it right back. That's when the distortion started. It's almost like PT is about 20 dB hotter than it was a few minutes ago. Even when I bounce files, the resultant waveform is now an almost solid rectangle... no dynamic range to speak of... and crazy distortion. Why?
Also: I attempted to throw out my pref files. I could not find any com.digidesign.plist (or anything obviously attributable to PT, Avid, DigiDesign) in my preferences folder. Is it normal now to have no pref files?
-DaleB
(Pro Tools 9. Digi 002. Mac tower 8 core. Snow Leopard. D-Command.)
Old 11-09-2012, 01:09 PM
Default Re: Distortion
I just upgraded to PT10. That didn't fix the problem. It's still distorted. Arg.
Old 11-09-2012, 04:47 PM
Hanswurstlsepp Hanswurstlsepp is offline
the name of the ProTools prefs file is "Pro Tools Prefs".
It is located at: HD/Users/your user account name/Library/Preferences/Pro Tools Prefs.
If you cannot see your user library folder, then keep alt key pressed while you click on "Go" within Macs menu bar.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
RMS and distortion. yamahadrums General Discussion 4 11-06-2012 11:21 AM
Distortion... Fortydub Windows 2 01-30-2012 09:58 AM
distortion help robgreen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-12-2005 02:59 AM
002 Distortion tg4878 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2004 07:47 AM
Distortion Mark Tandy Digidesign Hardware & Software 2 05-17-2001 10:13 PM
