question about audiosuite gain plugin
Does using the audiosuite gain plugin a bunch of times on a vocal track degenerate the sound quality in any way? I found that using this plugin a bunch of times on a track, freed me from trying to get the volume right automating with the 002.
Thanks! Keith |
Re: question about audiosuite gain plugin
freed you....you answered your own question. Obviously, you love the results or else you won't keep using it. Hence the audio quality is good,
Personally I use it without s seconds thought. Technology is amazing these days. If the initial signal is digitally clear so to speak. There is no reason to worry about inherent noise like way back in the day with analog tape. Unless you grew up in those times, you have no need to worry about degradation of sound. |
It should be fine for many generations, especially in a 24-bit session. If your session is 16-bit, and if you process the same portion of audio a few dozen times, you might begin to notice some dither build-up if your prefs are set to use Audio Suite dither. That would probably be about it.
If you're worried about it, do a nul test. Keep track of the changes you've made to a single region, and then place the original on another track with an inverted trim plug (aligned with sample accuracy). Bypass all plug-ins on the processed track. Set the volume fader of the unprocessed track to the level that is the sum of the changes you made using the gain plug-in. Solo those two tracks and listen to that region. You should hear nothing (if they're identical except for phase, they'll cancel each other out completely). If you hear little bits of jittery noise, then some degradation has occured.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
AudioSuite Gain plugin removes waveform | Fader Invader | Pro Tools TDM Systems (Mac) | 1 | 12-17-2004 08:36 AM |
Gain from audiosuite | Bodhisan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-24-2003 10:44 AM |
question Re: Gain (Audiosuite) | arche3 | Pro Tools TDM Systems (Mac) | 13 | 05-27-2003 12:03 AM |
audiosuite plugin question | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-19-2002 05:32 PM |
