Re: D-Command/Control and MDW-EQ6 band solo
Misread your list because the picture was sideways.
ok, took another look, yup, the band solo is not in the default map but is available as a custom map. So I can map the band solo to a fader but that doesn't really address the issue that it is missing from the default setup. Personally, I think it shouldn't require making a custom map to access this common used function. hmmm When you press Plug-in in the Focus Channel section of your console, the plugin parameters spill to knobs, yes? Do any of the knobs or the buttons below them turn band solo on and off for you?
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS Last edited by Will Russell; 02-21-2021 at 01:13 PM. |
Yes, one of the buttons under the 'GAIN' of that band will toggle the solo on and off.
This is in the custom fader section, and the inline encoders. |
Huh. Which version of the MDW-EQ6 are you running? mine is 6.0.3r27
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
Picking this thread back up again. My original issue with MDWEQ6 is that when I select plugins from the focus section of my D-Command and the plugin parameters spill to knobs and faders, there is no button to engage isopeak like there was with the MDWEQ5. I understand that that this does work on a D-Control with a button under the gain knob but no such button on my D-Command provides this function. I have reset the D-Command and reloaded the drivers, tried different version of ProTools, no love. It would be incredibly helpful if someone who has a D-Command and the MDWEQ6 could tell me whether their control surface provides this function. By the way, I have the original blue version.
last bump on this before i give up
will mdw eq v6 allow you to open old sessions created with v5 and map the settings correctly?
Key command for clearing playlist solo? | reichman | Post - Surround - Video | 10 | 02-24-2023 11:52 AM |
What happened to the band solo buttons? | quadraphonics | Avid S4/S6 | 4 | 04-19-2019 07:09 AM |
EQ 3 7-band solo feature not working | bluesguy76 | Pro Tools 12 | 4 | 12-17-2018 02:44 AM |
Going from solo bedroom DI to recording full band? | De93 | Pro Tools 10 | 1 | 11-23-2011 07:55 AM |
Digi EQIII 7-band and Command 8 | jimlongo | ProControl, Control|24, Command|8 | 1 | 06-23-2005 02:44 PM |
