Old 03-29-2014, 12:45 PM
def3mno62 def3mno62 is offline
Default The video engine could not start the playback because the clock isn't locked?
I get the following error when trying to play a video in pro tools "The Video Engine could not start playback because the clock is not locked. If this persists try deactivating or removing native plugins." I have no plugin's enabled so I have no clue what its talking about. Anyway any help would be appreciated
Old 03-30-2014, 11:34 AM
Stig Eliassen's Avatar
Default Re: The video engine could not start the playback because the clock isn't locked?
Your profile suggests PT 10.3 edu or whatever. What's your setup?
Help us help you
Old 04-04-2014, 12:43 PM
[email protected] vh@umbodid.is is offline
I ran into this using PTHD11.1.2 (Native PCI, osx10.8.5)
The culprit turned out to be an old version of ReVibeII plugin (11.0.1 - August 2013).
I installed v.11.1 (December 2013) and this dissapeared.
AVID video engine playback issue Audio_Vision Pro Tools TDM Systems (Win) 4 04-08-2011 01:09 PM
What do you set you playback engine to on a video satellite LE system? kd_special Post - Surround - Video 3 03-09-2011 07:04 AM
Playback Start Lag With Video On Line Cush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-12-2010 01:39 PM
Error - Network Clock is not Locked - Video Satellite Naught1 Post - Surround - Video 5 02-17-2010 08:12 PM
Can't start Hardware or Playback Engine dialog in PT LE Digi001 fsilano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-01-2001 11:28 AM
