With ProTools 5.1.3 (AVoption) on a G4 (Mac OS 9.1) I have the following problem: whenever I open an existing Session, (lets say on Audio Hard Drive A) ProTools (or the OS or whatever) creates an empty folder (with the same name) on all other hard drives including the system drive. So let's say I opened ten different sessions I always have to delete ten empty duplicates on all other drives, which drives me crazy because on busy days you always have to look and search for the real sessions... Maybe someone can help
Do you have your session default set to ROund-Robin on the disk drives?
cheers georgia
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
Hi Georgia,
Round Robin is definetely off. Also empty folders are being created whenever I o p e n a session (without recording). cheers Wolf |
Check your disk allocation for the session. Even if round robin is off, every time you launch a session a folder will be created on every disk that has a track allocated to it. This often happens if you move a session from one disk to another and forget to re-allocate the tracks.
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
Hi Davip,
I checked disc allocation and all tracks are allocated to the same drive. But it's the AVoption that I suspect now because I found out that the Video Track can be allocated to two different drives which has been the case. On the other hand that doesn't really explain the appearance of empty folders on the system drive (which hasn't been allocated nor to video neither to audio) |
Help Tab still empty | smetaxas | Pro Tools TDM Systems (Win) | 0 | 03-25-2008 06:16 AM |
how do i empty the clipboard?? | pkingduk | Pro Tools TDM Systems (Mac) | 8 | 01-29-2008 12:35 PM |
Help! Region bin empty !?!?! | Allbaldo | Pro Tools TDM Systems (Mac) | 3 | 05-26-2006 08:50 AM |
Where to buy empty "i-lok" in LA ? | KenSluiter | Pro Tools TDM Systems (Mac) | 4 | 05-17-2005 08:44 AM |
Help! Audio Bin is Empty | moosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-22-2004 09:40 PM |
