ongoing midi issues with PT
i am one of three people i know that has lost midi function in the last few versions of PT. i use a midiman/m-audio midi device that is sending and receiving fine (i even reinstalled their driver a few times to make sure), and protools refuses to accept any midi signal. i am using the mbox with a powerbook running osx (newest version). when i go to my audio/midi setup, it shows some odd unknown digidesign device as a midi box. this has a questionmark through it, and seems to not serve any purpose. obviously, the system is trying to see something that isn't there... prolly part of the glitch. the rest of the setup looks fine, but will not accept messages coming from any controller. it will send midi out oddly enough. does anybody have any idea what might be going on?? midi used to work perfectly for me until a few weeks back.
thanks! |
Re: ongoing midi issues with PT
I've had an ongoing problem with core audio/core midi where I've basically had to do a new set up after each reboot or PT freaks out and Reason doesn't see my Mbox. I haven't figured out if this is a problem with my Oxygen 8 driver, PT or Core Audio/Core midi.
GRRR
************ Steven Vertel Mixing / Mastering Engineer High Rock Records & Studio NYC http://highrockrecords.com |
I'm using an Oxygen 8 and the midi works. When I first installed the new core audio drive I had the wierd problem in the midi setup too. I deleted the device with the question mark and had to switcg the out on my oxygen to the other midi out (there two) and everything has been fine since.
After downloading and installing PT 6.1.1 and the 6.1.1 Core Audio Driver I couldn't use the midi in or out on my Digi002. I deleted the Digi midi driver in the audio midi setup and everything went back to normal. I think the Core Audio Driver 6.1.2 is supposed to fix all the midi problems also but I still deleted the driver cause I don't use it with anything else.
- Jason |
i have tried deleting this, but nothing changes....
are there any digi support people in here who can give me any info?
they haven't said a damn word about it.. the only way i got mine back was a reformat of the drive.. even when i tried to completely erase anything digi related it still would not work for me..
good luck.. ive been there before.. |
i redid my whole computer, and i am still having issues with this. do i need to look for older pt6 installs? this is going to be insane trying to figure out which version killed my midi.
digi... you guys have any ideas? |
digi...do you care to answer at all?? this is crazy! i rebuilt all my system and still have no midi!
Download issues still ongoing? | danander11 | Pro Tools 9 | 0 | 12-12-2010 06:25 AM |
Protools 8 ongoing issues | Gravyblue | Pro Tools TDM Systems (Win) | 0 | 12-04-2009 01:41 AM |
7.4.2 ongoing issues - stuttering, freezing and more | RW1965 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 07-15-2008 06:13 AM |
Ongoing problems with Octopre and Digi002 | Transmission | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 10-10-2007 11:34 AM |
Ongoing MIDI developement in ProTools | southbound | Pro Tools TDM Systems (Mac) | 5 | 09-07-2004 11:28 PM |
