Old 03-16-2023, 02:56 AM
soundstudent soundstudent is offline
Default creating a new pro tools session opens 4 empty folders on my desktop
everytime i open a new pro tools session 4 folders are created on my desktop.
I am very much a beginner and have not found a fix for this as yet.
can someone help?
tia
Soundstudent
Old 03-16-2023, 03:27 AM
dominicperry dominicperry is online now
Default Re: creating a new pro tools session opens 4 empty folders on my desktop
It's most likely that you have a default path in preferences which has somehow changed to your Desktop.
Have a look in Preferences -> Operation (tab) -> User Media and Settings Location.
Also check the "Open Session" or "Create New" dialog box - at the bottom there is a default location for files - again, this may be set to your Desktop.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Monterey 12.6.6, Pro Tools 2023.3, Carbon.
Old 03-16-2023, 08:01 AM
In addition to Dominic's post; When you open a session, various support folders (session backups, video, audio, bounce) will be created *within* the folder that the session file is located on. If that session file is sitting on your desktop (without a surrounding session folder) then those folders will also reside there. When you create a *new* session, Pro Tools will create a folder for it and all those aux folders will reside in that session folder.
http://www.richbreen.com
Mac Studio / Ventura, MacPro 5,1 Dual Hex, Mojave, PT 2023.3.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio / Monterey / HDX / MTRX / S6
Old 03-16-2023, 08:06 AM
Hi Dominic and Rich
thank you both for your replies
I have checked all these folder locations as you suggested but none are set up for desktop unfortunately.
Rich, these are the exact folders that are being created on my desktop, but again pro tools is never instructed to save any new session to my desktop (unless I decide to save there (prompt for location)
my lecturer is also puzzled with this and he is the Avid expert at college
'scratches head'
Old 03-17-2023, 04:34 PM
Is this only on creating a new session or only on opening an existing session or both? Where are these sessions located? System drive or external drive? Post a screenshot of your Disk Allocation window, A Workspace:Volumes window (Option-I), and perhaps a screenshot of your New Session dialog box when you create a new session. Also some system information would be useful: Computer, OS, PT version, Peripherals, etc.
Old 03-17-2023, 06:20 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
What are these folders called?
Mac mini M2 base model, 16GB RAM. MacOS 13.2.1. PT Studio 2023.3.
Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Avid Control on iPad.
Old 03-18-2023, 03:26 AM
Hi Ben and Rich
folders are - clip groups, audio files, video files, bounces files.
It seems to only be happening with a new session on the system drive, no external drive yet. also when i close the session the folders disappear.
ive updated my profile to show my system specifics, let me know if there is something ive missed.
ive attached screenshots as suggested. re Disk allocation - im thinking i uncheck, create subfolders and change my folder location? - just tried this but still im getting folders on my desktop ..... the new folder location has stayed the same but creating subfolders is checked again...
oh dear.
any other ideas guys?
thanks so much for taking the time to help me out !
Old 03-18-2023, 03:31 AM
more screenshots
Old 03-18-2023, 06:38 AM
The four folders you are seeing are the standard folders that is automatically created inside every session folder along with the session file itself. (Actually, there should be a fifth folder, Session File Backups). A PT session file is always inside an enclosing folder like this. So it sounds like PT is somehow treating your desktop as the session folder. I never saw that before, and I don't know why it would happen. I've tried to replicate without success.
It should work, though - I bet there is a .ptx session file on the desktop along with the folders, and when it is opened, it will look for audio in the Audio Files folder etc.
When I create a new session from the PT Dashboard, PT creates a folder with the name of the session, and places the five folders inside it, along with the .ptx session file itself. That's how it works. And when you close the session, if the folders are empty they might disappear as the are not needed yet.
Try to make sure when you create a new session, that you see exactly where it's being created. For example; create a folder on your desktop called 'sessions', and save the new session inside that. You should get a normal session folder with the session file (.ptx) and its associated folders inside it.
That's all I have.
Old 03-18-2023, 06:45 AM
K Roche's Avatar
K Roche K Roche is offline
Yes the first thing definitely wrong is on your "Dashboard" towards bottom in the "Location " box It should not be saying "Applications/stufit/LogicPro./
and my guess is that is why it is throwing the subfolders to your desk top because it cannot store them in Applications
Have no clue how that location got there but that is definitely not a valid storage location for Pro Tools. And BTW any supposed "Avid expert " should know that is all wrong instantly by looking at your Dashboard .
In fact the default location when you first install and launch Pro Tools should be Mac "Documents "
Ok to back up and start over :: First trash your Pro Tools Preferences
#1 Close Pro Tools and launch Finder.
# 2 Click Go and select Go to Folder…
#3 Enter ~/Library/Preferences/Avid and click Go.
#4 Delete the Pro Tools folder.
# 5 Restart your computer and launch Pro Tools.
PT Dashboard should launch with Documents as the default "Location" path and you can use that BUT I prefer not to have my PT sessions in with any other Documents ...
SO
I suggest create a folder on your desk top and label it something like (your name) PT Sessions
And you want those sub folders may be very handy in the future and they should be automatically placed inside the main session folder
Then on your PT Dashboard click Location (grey circle) and then click Location rectangle you be able to at least see Mackintosh HD if not the Desktop and should be able to then select click on Mac ntosh HD , and see "Desktop" in the left widow -select it and then select your new PT Session folder that you created and select it and then the l
"Location" path should change to that path ...
Now just remember to check and see that your created Desktop PT session folder is the Location (sometimes it try's to go back to the default Documents location but you can click the Location rectangle box and change to your desktop folder
If for some reason you can change the location after Trashing Preferences then I would uninstall Pro Tools and then re-install it. ........good luck
System :
Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Ventura 13.2 .1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
pro tools 2018.12 crashing before session opens mixedbywade Pro Tools 2018 2 08-29-2021 10:18 AM
How Do I Stop Pro Tools From Creating Shared Folders In Vista? GNA Pro Tools M-Powered (Win) 5 07-30-2015 10:46 PM
Structure opens empty when I load older session andygray Virtual Instruments 1 02-04-2010 11:10 AM
Corrupt session file? Opens up completely empty. jonnyb8390 Pro Tools TDM Systems (Mac) 9 02-07-2008 07:47 AM
Empty Folders Issue steppenwolf68 Pro Tools TDM Systems (Mac) 4 01-08-2004 05:09 AM
