Old 02-06-2008, 09:41 AM
jonnyb8390 jonnyb8390 is offline
Default Corrupt session file? Opens up completely empty.
Running a G5, 10.4.11, 2GHz PPC, 1GB RAM, HD2 system with v.7.3.
This has happened a few times now, where I open up a session that has been worked on, and nothing shows up in it. No tracks or audio files. This hasn't been a big deal since I backup regularly, but I'd like to get to the bottom of it eventually!
Also, when I install the cs updates, it is not indicated in the menu bar, or "About ProTools". Is this related, since I thought that one of the updates was supposed to fix data loss?
I reluctantly admit that I do have a UAD card installed running v.4.9. Please don't be like my doctor and automatically assume that the UAD card is the problem.
Any help would be greatly appreciated.
Thanks!
Old 02-06-2008, 09:57 AM
DigiTechSupt's Avatar
Default Re: Corrupt session file? Opens up completely empty.
What type of drive(s) are you storing your sessions on? Were those drives formatted using the OS X disk utility?
Do the sessions open up blank, as in there's no regions in the edit window, or are there regions, but no audio? If the latter is the case, does the Tasks window show that it's trying to relink?
Avid Audio Tech Support
Support FAQ
Old 02-06-2008, 10:10 AM
In most cases, the drive is an internal "Seagate" (I'm pretty sure that's the brand), independent of the System Drive - not a partition. Yes, they are both formatted using Disk Utility.
However, in this most recent situation a session folder was copied from this internal drive described above, to an iPod and transferred to the desktop of an identical system (as identical as you can get with authorizations and such).
When the session opens, there is literally nothing. No tracks even for the region to display faded. Opening up the region bin shows nothing, which leads me to believe there wouldn't be any Audio Files to search for.
Any ideas?
Old 02-06-2008, 10:14 AM
Ale Ale is offline
are you on
7.3 + cs
or
7.3.1 +cs
As I remember did 7.3 produce corruption
ale
2 PT HD Ultimate 2023.3 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.3 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 02-06-2008, 10:30 AM
I've tried updating to 7.3.1cs5, but it won't indicate that I actually updated. It only shows 7.3.1. Shouldn't the version be displayed in the menu bar, and the "About ProTools" as 7.3.1cs5? Is there the possibility that I'm not actually updating to the "cs" version?
Old 02-06-2008, 10:52 AM
Pro Tools does note reflect the installation of cs updates. You just have to know the version of the cs update you last installed.
The only way it wouldn't have updated properly is if the installer crashed or something. If the installer went through without a hitch, then the cs update is installed properly.
Support FAQ
Old 02-06-2008, 10:56 AM
Any ideas?
So this problem ONLY cropped up when doing the transfer via iPod? If so - on what machine was the iPod originally formatted - Mac or PC?
Have you possibly tried moving the session via another method - hard drive, CD/DVD, etc? If so, did it work?
Support FAQ
Old 02-06-2008, 12:13 PM
Stylin' Audio Stylin' Audio is offline
FYI, doing a "Get Info" (Apple-I) on the Pro Tools application in Finder will display the CS #.
Colin Van Hattem
Noizemaker Productions
Old 02-07-2008, 07:44 AM
The iPod was formatted on a Mac. I realize that this iPod adds another variable into the equation, and maybe I'll just have to wait until it happens again and be very diligent when documenting the problem. Before this last instance (only happened 2-3 times over the period of about 6 months), I had assumed "operator error" and had no way of knowing what exactly transpired. I know for a fact that some clients come in with drives that are partitioned, one for Mac and the other for PC (very bad karma), so I have to take that into account as well.
I'll try transferring via flash drive and if no miracles occur, I think it's a wrap. I appreciate all your help and hopefully I won't encounter this problem again.
Thanks again.
-Jon
Old 02-07-2008, 07:47 AM
Thanks Colin, that was a very useful tidbit of info and I am in fact running the cs5 update.
-Jon
DAE 9073 error due to corrupt PT 10 session file bom619 macOS 1 06-22-2012 09:21 AM
Structure opens empty when I load older session andygray Virtual Instruments 1 02-04-2010 11:10 AM
corrupt session file!!!!! Sounds Suite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-18-2006 03:50 AM
corrupt session file J J Macrae Pro Tools TDM Systems (Mac) 1 07-02-2002 02:50 PM
Ouch!!! Is my session file corrupt?!?! maphew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2002 11:03 AM
