  #21
Old 02-20-2023, 05:50 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: i913900k Users
Originally Posted by LDS View Post
Yeah, it looks like all the Intel 'tech' is enabled by default. Speedstep, Turbo Boost, Speed Shift, & Turbo Boost Max 3.0. Intel Velocity Boost Voltage Optimisations is set to auto.
OK. In my case, I've disabled all of those and have a manual all-core overclock. I guess things have changed. Some time ago PT didn't like voltage changes.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #22
Old 02-20-2023, 06:36 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by lesbrunn View Post
OK. In my case, I've disabled all of those and have a manual all-core overclock...
Same.
Click for audio/video demo
Click for resume
  #23
Old 02-21-2023, 02:40 AM
lesbrunn's Avatar
Originally Posted by EGS View Post
Same.
Hey EGS,
What cooling solution do you use? Do you also experience extreme thermal peaks when carrying out heavy tasks? When I was using the i712700k / Pro Z690-A DDR4, I was able to overclock it stably to 5.2, but never got the sort of peaks I saw recently with the i913900k.
Strangely, even with stacks of plugins, PT seems to perform efficiently within very reasonable thermal bounds. The only task that took me to 100c was Izotope's RX9 and 10 when performing a stem separation. I haven't yet used Ozone since I upgraded, but I'll check as soon as I have some time. For now, I won't even go anywhere near Acustica till I've finished the current project.
  #24
Old 02-21-2023, 10:04 AM
EGS's Avatar
EGS EGS is offline
Hey EGS,
Air cooling - 2 push-pull fans on the CPU cooler plus case fans. All fans are super-low db fans. The only time the CPU gets hot is on some heavy-lifting type video edit sessions, since video renders can max-out all cores to 100%. For Pro Tools though, no heat issues!
As far as CPU spikes - typically caused by an old or poorly coded 3rd party plug.
Click for resume
  #25
Old 02-21-2023, 10:22 AM
lesbrunn's Avatar
I no longer have CPU spikes in PT, just heat on heavy tasks.
  #26
Old 03-29-2023, 07:00 PM
EGS's Avatar
EGS EGS is offline
Have you tried a lower clock, like 5.2GHz or 5.3 instead of 5.5? Maybe that would help with heat on heavy tasks? On my 11th gen, during a long video render (which hits ALL cores at 100% for the duration of the render) I will temporarily lower to 4.8. To keep temps safe, then back to constant 5.1 for Pro-Tools.
Click for resume
Are Windows users seeing the same bugs as Mac users? poly915 Pro Tools TDM Systems (Win) 2 08-13-2007 10:08 PM
Are Windows users seeing the same bugs as Mac users? poly915 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-11-2007 07:51 PM
To The PowerBook users (and also WAVES users) ·[-_-]· Richon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-05-2005 06:42 AM
vst2retas users inhere? non-users, read this to ! ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-09-2004 03:41 PM
Need users opinion: New digi users domain name (unofficial).. David Fisher General Discussion 2 07-30-2002 09:27 PM
