Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-04-2000, 11:43 PM
jjblair jjblair is offline
Default ULTRA WIDE 3 LVD
I'm considering putting in an Adaptec PowerDomain 30160 Ultra 3 LVD in my Beige G3/300. Based on what I'm seeing you guys post, I'm also considering skipping getting the Sawtooth and just accelerating my G3. Has anybody tried the Ultra 3 yet? I know that Ultra 2 is approved, I think. And Quantum makes a 10,000 rpm ultra wide 3 drive. Comments please?
Old 02-06-2000, 03:47 PM
Ron Galbraith Ron Galbraith is offline
Default Re: ULTRA WIDE 3 LVD
I've been using the new adaptec 39160 since it came out a couple months ago, and have not had any problems. Even though it is capable of running at the very high throughput, you still have to throttle it back in the power domain control panel to 20mb/sec, so don't buy it just for the high throughput. I bought it because I found it cheaper than I could get a 3940UW.
Old 02-07-2000, 11:24 AM
What is the reason for ProTools only being able to handle 20mps throughput? I was hoping to cut down on DAE errors from running too many edited tracks without having to add another drive. I was asssuming that a wider SCSI throughput and a 10,000 rpm drive would help. Is this not the case?
Old 02-10-2000, 09:37 AM
batman batman is offline
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by jjblair:
What is the reason for ProTools only being able to handle 20mps throughput? I was hoping to cut down on DAE errors from running too many edited tracks without having to add another drive. I was asssuming that a wider SCSI throughput and a 10,000 rpm drive would help. Is this not the case?<HR></BLOCKQUOTE>
This is indeed the case.........
Pro Tools doesn't like too much activity on the PCI buss, so ultrawide SCSI accelerator cards have to be "strangled down" to 20Mb/s data transfer rate.
I mainly use single buss Atto or Adaptec cards in my rigs (although I do have one 3940 dual buss) and find I can pull the full 64 voices with heavy editing/automation off one 9Gb Cheetah 39102LW drive!
The company I work for has many of these drives, and, as they are also used in RADAR2 systems, we can swap them between the two systems.
Ade
Regular Ultra wide -Ultra 3-enclosures the same? elementsound Storage Subsystems 0 07-03-2004 01:43 AM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 06:40 PM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-09-2000 05:21 PM
scsi ultra wide is better? gigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-14-1999 01:36 PM
Ultra 2 Wide Hard disk Michael TY Au General Discussion 3 08-24-1999 12:10 AM
