Change Of Behaviour With Fades/Audiosuite?
Hey all,
I'm seeing a change of behaviour with the way PT handles fades and Audiosuite, and I'm wondering if anyone has a workaround (or knows where to find a way) to get back to previous or similar behaviour. I make a lot of sample content, (drum samples mostly) and quite a lot of my workflow relies on batch processing. My previous workflow (on my old machine running PT2019.x) was that a bunch of samples laid out in the timeline could all have a fade applied to the end (Command>F and select the fade out length). I would then write those fades to the individual files using a little workaround: I'd select the Trim Audiosuite, and using "Create Individual Files" I would then audiosuite them and it would write the fade to the clip, in the same way that "Consolidate Clip" does.... but it would do it to multiple clips at the same time. I would then Batch Rename and export those samples to be loaded into Kontakt. The way it works now is that Audiosuiting the individual clips doesn't write the fade to the file... It now basically "Trims" the file (even though no gain is being applied) and leaves the fade unwritten to the clip (the fade is still visible as if it's overlaid over the clip)... so there's now no consolidation of the fade happening. Anybody got a better/different workflow for dealing with this? I basically need to be able to create fades at the end of multiple clips and consolidate that information to all those clips before export, without having to individually consolidate multiple files. Thanks in advance..!
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe Last edited by Jon_Atkinson; 11-05-2021 at 07:15 AM. |
Re: Change Of Behaviour With Fades/Audiosuite?
Turn off Handles. Try using AudioSuite Gain at 0/0 instead of Trim.
Thanks so much...!
That's exactly what it was.... Once I searched "Handles" in the manual it all made sense...! p.963 of the manual explains it nicely with the various Audiosuite options and whether fades and clip gain are rendered or not. Much appreciated
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
Glad you got it sorted.
Change in Tab key Behaviour? | nhaudio | Pro Tools 12 | 2 | 06-14-2016 08:10 PM |
Fades and Audiosuite Not Working in Pro Tools 12 | firsty33 | Pro Tools 10 | 3 | 04-29-2016 12:47 PM |
when did VCA behaviour change? | tomlowd | Post - Surround - Video | 6 | 08-21-2011 10:21 PM |
Audio region behaviour on tempo change | moqtev | Tips & Tricks | 1 | 11-13-2006 01:08 PM |
PTLE 32 and plugs: weird fades behaviour. | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 12:40 AM |
