Re: Dual Boot?
Appreciated Skooter |
Re: Dual Boot?
Every once in a while a CCleaner update tries to install Avast or similar. Do NOT let it install any other crapware - perhaps with the "custom" install options. The reg scan lets you review items before deleting, so you can always opt out. I only see reg clean entries after I install/uninstall something, so the items it selects for reg cleaning generally make sense to me. Having said all this, I have not had any problems with CCleaner in a long time. EDIT: In CCleaner ---> Options --->Updates ---> UNcheck (& ocassionally check for CCleaner updates manually).
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume Last edited by EGS; 11-14-2021 at 08:14 AM. Reason: added one more thought |
Re: Dual Boot?
No issues here with CCleaner and I run it every day. In addition to showing you what it's going to delete, it offers to save the Registry before you delete anything. If something does go wrong, just restore the file. And yes, I image my drives nightly for peace of mind sleeping.
Re: Dual Boot?
Re: Dual Boot?
No, I've never had to restore the registry, but any chance to save in any program, I take it.
Re: Dual Boot?
I usually use the "portable" version, standalone .exe that doesn't install.
Download the latest version when I want to use it and delete it when I'm done. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Re: Dual Boot?
Creating Restore Points before any major updates/experiments can be very helpful if things go south. I've rolled back with restore points a few times over the years without issue. I'm also a fan of CCleaner. They quit offering additional app installs a while back (at least on updates). There was probably a bit of push-back from the user base. I also find Wise Registry Cleaner a useful utility. https://www.wisecleaner.com/products.html
PT 2023.12 DP 11.3 MOTU M4 HP Envy 8G i7 Quad Laptop Win11 PT 2023.12 DP 11.3 828es ADA8200 MTP-AV 2023 MB Air Sonoma VEP 7.x with various VIs on HP Z2 G4 Xeon Workstation Win11 |
Re: Dual Boot?
However, consider the drawbacks - your PC WILL take longer to start up because it has to prompt you which drive you'd like to boot into. You WILL have to shut down and reboot your computer *any time* you have to open Pro Tools. You WILL NOT have access to the other files or programs on the other partition. Depending on what you do, this could make Pro Tools impossible to use in conjunction with other programs for things like video and screen recording, podcasts, lectures, video calls, etc. unless you want to download the same program on both partitions and have it take up twice as much space. That said, the golden rule is always to have your actual project files on a separate drive, and to record on a separate drive. That ensures not only that Pro Tools won't get bogged down between recording to the same drive it's on, but it also preserves your HDD / SSD lifespan because your scratch drive is not your main drive. There are performance and professional advantages for having a separate computer entirely - one for work and one for video games and other fun stuff. Ultimately that depends on who you are though, doesn't it? Are you a hobbyist? A professional? If you're a hobbyist, keep it on one partition and one computer. The less hoops you have to go through, the less likely you are to kill your own inspiration. If you're a professional, have a dedicated Pro Tools system. That way, when you boot up your Pro Tools system, your psychology switches to "work mode". When you switch back over to your regular desktop, you transition over to "play mode". The psychological aspect is a very real thing. |
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files | taylor4814 | Windows | 1 | 02-16-2012 05:54 PM |
Boot Camp - Dual Boot, Dual Versions of PT LE? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-17-2009 04:15 AM |
Help with Dual Boot on Dual 1 ghz QuickSilver | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-13-2005 06:12 AM |
Configure Dual Boot on New dual 1.25?? | cliepe12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2003 04:45 AM |
XP/WIN 98 dual boot | brianpatrick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-04-2003 10:30 PM |
