Using MultiSource LTC in ProTools?
How does one use LTC time code captured on an audio track from several multi-track audio sources. These include several digitral video cameras and several multi-track digital audio recorders.
Seems LTC is not supported? Works in Avid but not ProTools. Hmmm. Has anyone done this and how was it done? Rick |
Not quite sure what you mean by multisource LTC. PT will only lock to a single timecode positional reference.
The usual method of doing this is with a Sync IO or Sync HD peripheral. You'll find info on this in the PT manual. G |
Re: Using MultiSource LTC in ProTools?
Yep, but according to many sources the poor man's method (LTC/MTC coverter) works too, which is a good thing. There are many situations where getting an HD system just for the LTC I/O via the Sync HD interface would be an expensive overkill. It's good to know that i.e. RME HDSP interfaces with the TCO daughter card can extract Word Clock from a video signal and can convert incoming LTC to MTC internally (in both directions).
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
I have ProTools 8, But Avid is only giving me ProTools 7.x Authorization Codes | jpsaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-14-2012 08:34 PM |
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? | jgbsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2011 01:08 AM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
