headphone output?
Hi there
I am absolutely loving my D-command! Great piece of gear. This may sound really, really stupid, but I'm guessing that on the front right of the main unit is that a headphone output? And, how do you get it working.? I'm laughing at myself even writing this Cheers Kim |
Re: headphone output?
The "Phones" button on the upper left corner of the Cue section can monitor any one of the Cue sources you see there. You have to have I/O outputs wired to the X-Mon to feed the Cue system though. You might be able to hear something already if you have your I/O outputs wired to the X-mon's Main Inputs. Just press the "Phones" button to turn it on, then press the Set Source switch to cycle through the different sources, one of which is the Main Monitor Input.
Mark Ettel C.A.S. |
Cheers Filmixer
It works a treat, and also answers my other question on how to check/monitor the cue sends. Much appreciated! Kim |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
003 Rack - Alt Mon Output to Headphone Amp? | lowlights | Windows | 4 | 10-17-2011 12:04 PM |
headphone output low on 8.03 with 003 | Mothlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-13-2010 01:41 AM |
LLM no headphone output | brinogordon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-06-2010 12:08 AM |
