Click in 6/8
Got a track in 6/8, temp is 53.3333bpm (don't ask - it was started as a 6/4 session, with a quarter note = 160...).
However, I can't figure out how to get the click to sound on all six beats of the measure. Currently the downbeat click sounds and the secondary click sounds on 1, 2 and 3, but is silent for 4, 5 and 6. Any ideas? Thanks again in advance! Screen Shot 2016-02-11 at 7.42.44 AM by gdgross2001, on Flickr Screen Shot 2016-02-11 at 7.42.57 AM by gdgross2001, on Flickr |
Re: Click in 6/8
click on the little Plus Sign next to Meter in your Edit Window Timeline .. change that Click to 1/8 note .. should do what you want ...
this is different from the Click in the Bar at the Top of PT Edit Window .. that remains at 1/4 note cheers john
Re: Click in 6/8
And maybe click to highlight "Follow Meter" in Click II ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Re: Click in 6/8
yes, this needs to be on .. and you have to change that Click Ref in that window .. it is odd to me the way we have to do this ..
Re: Click in 6/8
I'm working a piece that's in 9/8 which is essentially 3 1/8 notes to beat so I set the meter to 1/4 note plus ". "time and it solved everything
- Steve 2013 iMac Late model i7 3.5 Ghz quad-core, 24 gigs ram, OSX 10.12.3 PC slave, i7 6700 4.0 Ghz quad-core, 64 gigs ram, SSD drives running VE Pro 7 Multiple external thunderbolt SSD hard drives UAD Apollo X8, Twin Duo & Quad Satellite Thunderbolt Townsend Sphere L22 w/ Putnam Mic Collection LUNA (I have Pro Tools 2020 as well) |
Re: Click in 6/8
Thanks guys! Easy fix
Re: Click in 6/8
steve, so you set to Dotted 1/4 note ... did you do this in the Main Edit Window Click or in the Meter Click Window ??
gdgross, Good to Hear you are good .. and we are all learning a couple new ways to do things .. i know i am .. cheers john
Re: Click in 6/8
I had the same problem and i got the solution. First select the region where you have the different meter and then press ALT+1 (Only numeric pad) Time Operations window will be open and then you can change the click to 8ths or 16ths or wherever you need, press apply and Voilá.
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
Getting the click track to click at 16th notes... | broken81 | Tips & Tricks | 1 | 06-27-2008 07:06 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
Mbox needs TWO click plugins for the click to work | drguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-17-2004 12:01 PM |
Power Harness, click click click | director | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-14-2004 09:50 PM |
