#21
Re: PTDH 8.0.1 CPU issues are still there!
I'll reply once I have more information on how to proceed... |
#22
Meat and x9blade - can you both post your most current Sandra reports, run on the system exactly as it was configured when you did your last test?
Can you also tell me what's in each of the slots on the computer? |
#23
I'm getting -6031 errors non stop since the update.
SiSoftware Sandra Computer Model : HP HP xw8400 Workstation Domain : xxx Host Name : xxx User : xxx Processor Model : Intel(R) Xeon(R) CPU 5160 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : HP 0A08h BIOS : HP 786D5 v02.35 11/25/2008 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DDR2 FB-DIMM Chipset Model : HP 5000X Chipset Memory Controller Hub Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DDR2 FB-DIMM Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Samsung M395T2953EZ4-CE65 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M395T2953EZ4-CE66 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M395T2953EZ4-CE66 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M395T2953EZ4-CE66 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : NVIDIA GeForce 8800 GTX (128 SP 1.25GHz, 768MB DDR3 2x900MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8800 GTX (128 SP 1.25GHz, 768MB DDR3 2x900MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8800 GTX (128SP 1.35GHz, 767.7MB 2x900MHz) Storage Devices ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) : 699GB (C:) WDC WD7500AACS-00D6B0 (750.2GB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) : 699GB (F:) Apple iPod 30GB (USB) : 28GB (G:) HL-DT-STDVD+-RW GSA-H21L (ATA44, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 699GB (NTFS) @ ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) AUDIO (F:) : 699GB (NTFS) @ WDC WD7500AACS-00D6B0 (750.2GB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Optical Drive (D:) : N/A @ HL-DT-STDVD+-RW GSA-H21L (ATA44, DVD+-RW, CD-RW, 2MB Cache) Removable Drive (G:) : 28GB (FAT32) @ Apple iPod 30GB (USB) Peripherals LPC Hub Controller 1 : HP 631xESB/6321ESB/3100 LPC Interface Controller LPC Legacy Controller 1 : SMSC SCH5307-NS Audio Device : C-Media Electronics CMI8738/C3DX PCI Audio Device Audio Codec : Gammagraphx 0000h Audio Codec : Gammagraphx 0000h Serial Port(s) : 1 Parallel Port(s) : 2 Disk Controller : HP 631xESB/6321ESB/3100 Ultra ATA Storage Controller Disk Controller : HP 631xESB/6321ESB/3100 Serial ATA Storage Controller Disk Controller : HP SAS 3000 series, 4-port with 1064 -StorPort USB Controller 1 : HP 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #1 USB Controller 2 : HP 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #2 USB Controller 3 : HP 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #3 USB Controller 4 : HP 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #4 USB Controller 5 : HP 631xESB/6321ESB/3100 Chipset USB2 Enhanced Host Controller FireWire/1394 Controller 1 : HP TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 5X00/7X00 XMB Ch 21-0 SMBus SMBus/i2c Controller 2 : Intel 5X00/7X00 XMB Ch 21-1 SMBus SMBus/i2c Controller 3 : Intel 5X00/7X00 XMB Ch 22-0 SMBus SMBus/i2c Controller 4 : Intel 5X00/7X00 XMB Ch 22-1 SMBus Printers and Faxes Printer : Dell Color Laser 5110cn PCL6 (600x600, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Universal Printing PS (600x600, Colour) Printer : HP Color LaserJet CM3530 MFP PCL 6 (600x600, Colour) Network Services Network Adapter : Broadcom NetXtreme Gigabit Ethernet - Packet Scheduler Miniport (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Cards are: Slot Card CPU Slot 1 (PCI 32-bit) Diamond Sound Card CPU Slot 2 (PCIe) HD Accel Card CPU Slot 3 (PCIe) HD Core Card CPU Slot 4 (PCIe) Graphics card Nvidia 8800 GTX CPU Slot 5 (133MHz PCI 64-bit) Empty CPU Slot 6 (100MHz PCI 64-bit) Empty CPU Slot 7 (100MHz PCI 64-bit) Empty EDIT: When I bought that WD Drive it was listed as a 7200.. not sure why it's reporting 5400.. |
#24
http://imaginatlh.com/91709 |
#25
Also, to get back to your first question Meat, regarding CPU usage you say you get high cpu usage:
Cheers, Paul Vercellotti Avid Engineering |
#26
Can you tell us which troubleshooting steps from the General Troubleshooting thread you've done, specifically? All drivers up to date, etc?
#27
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
#28
I wanted to clarify a few things about this error.
First, it's new behavior to 8.0.1 and is there to warn of driver conflicts that may lead to corrupt audio. The error is resolved in most cases by making sure you have the latest drivers for all hardware installed on the PC, disabling any background processes or system services that may be causing driver conflicts or using up CPU time and disabling any extraneous hardware like network adapters, bluetooth, etc. that may interrupt Pro Tools. In a few cases, reversing the card order in the computer solved the problem - we're still investigating the root cause of this. I want to be absolutely sure everyone has done all this before proceeding. It's absolutely critical for us to properly evaluate your system and determine if there's something wrong outside of the scope of what we understand to be the fundamental cause of these errors. |
#29
except for: reformatting the audio drive disable remote desktop (work will not allows this) disable automatic updates (work will not allows this) |
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) | Lucky Bastard | Getting Started | 6 | 01-16-2014 03:29 PM |
No sound - asio driver issues - NTFS issues | mitchelljrickey | Windows | 0 | 06-21-2012 05:35 PM |
ProTools 9.0.5, iLok issues, Digi 003R+ issues | zachbot | Pro Tools 9 | 6 | 10-12-2011 08:19 PM |
8.0.4 Issues (Quick Punch & Mute/Solo issues) | pauledwards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-06-2010 09:35 AM |
Digital Noise Issues - Clock Source Issues? | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2010 01:55 PM |
