  #51
Old 06-16-2021, 02:46 AM
Cheesehead Cheesehead is offline
Default Re: The Hybrid Engine
He's talking about PEC/Direct monitoring for post production dubbing workflows. That workflow generally has multiple Pro Tools source machines playing back which then get summed and printed to a Pro Tools recorder (dubber) system. Part of that workflow is punching in when making mix changes. When you do that you want to be able to monitor those hardware inputs (Pro Tools source machine outputs) in low latency just as you would when overdubbing a guitar, for example.
Thanks Kyle,
Sorry for giving you the wrong time, doh!
So basically as Watagushu says, with a stem or mix record channel in Hybrid mode you can drop in and out without latency jumps, with the track not in input mode?
I can see that being very useful indeed!
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
  #52
Old 06-18-2021, 10:39 PM
Mark Ziebarth Mark Ziebarth is offline
Steve‘s workflow with the voice stealing has one advantage: It copies all the takes to the new location when you have to the change the arrangement. The newer workflows with playlists and clip effects miss this feature.
To fully compensate what the voice stealing in TDM did Pro Tools needs to get an advanced selection technique to include all underlying playlists when moving or copying clips on a track, right?
Or am I missing something?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
  #53
Old 06-19-2021, 09:42 AM
Bushpig Bushpig is offline
Hi All,
I decided to post a thread over on the Post Production sub forum, posing the question to the PP guys and girls about the voice stealing workflow.
Mark Ziebarth above has joined in over there too.
If anyone's interested in continuing the conversation from a different angle, this is the thread:
https://duc.avid.com/showthread.php?t=415743
I might try and keep the two threads cross-polinated for as long as it makes sense, unless that's against the rules (Mods?).
Cheers.
Steve
2 x Systems: MacPro 5.1 (Nehalem) 2 x 2.26 Quad Core, OSX 10.9.5 (Mavericks), PT10.3.10HD, 32 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O.
  #54
Old 06-19-2021, 10:28 AM
Mark,
PS. Everything you said above, I totally agree with. And that's just the start of what's beautiful about voice stealing.
Steve
  #55
Old 07-20-2021, 01:45 AM
Hi All,
New video added to the main thread over here:
Cheers.
Steve
  #56
Old 07-24-2021, 11:47 AM
kosmokrator kosmokrator is offline
Just finished my first Dolby Atmos mix with the Hybrid Engine.
Real game changer.
I just don't have to think about system resources anymore.
That mix had 300 tracks for a 7-minute piece with loads of 7.1.2 bussing, upmixers, tons of plugins etc.
And recording some missing foley during the mix was absolutely no problem. Record track in DSP mode, perfect recording experience.
Played completely without problems.
Combined with the new MacPros, this is a real step forward.
Congrats, great job on this Avid!
(Now please let's get the automation-doesnt-follow-moving-fades-bug out of the way)
  #57
Old 07-26-2021, 02:28 PM
dbcsound dbcsound is offline
Hi All,
We’ve been doing some testing with the hybrid engine and Atmos in a post-production workflow. We usually run a three pro tools system setup with atmos renderer on the dubber. We tested a layback session from last year and found that running the hybrid engine with DSP selected on the stem tracks that feed the renderer send and return plugins caused the audio to digitally distort(computer voice effect!). Not sure if this was an install error on our part or I’ve just missed the optimal workflow for this setup. Ideally I was hoping this could solve some of the problems with pec/dir monitoring and delay compensation. We generally leave Delay Comp. off so when monitoring the punch ins it sounds seemless. Any advice is appreciated or if anyone else has had this problem.
Thanks
Gord
  #58
Old 07-27-2021, 09:05 PM
Goombot Goombot is offline
I haven't tried that but I do want to do some testing putting some of my reverb returns in DSP and print. I'll let you know if I hear anything "off".
  #59
Old 07-29-2021, 04:51 AM
dtmprod dtmprod is offline
Default Re: The Hybrid Engine-large CPU hit
Seems like you post guys are happy with the new hybrid engine. I'm trying my first music mix & I'm rather disappointed with the large CPU hit I'm experiencing. My puter's a 3.46 x 12 core, so I'm not thinking its a slouch. I normally can mix with playback at 256. With the hybrid engine, I'm only halfway thru my mix & I'm already hitting 70% CPU with playback set to 1024. I've looked around the Avid site to see if there are any suggestions for optimization, but not finding any. So I'm looking at reverting back to original HDX mode so I can mix like I usually do. If anyone who does music mixing has any observations/suggestions, I'd greatly appreciate it. Thx
  #60
Old 07-29-2021, 06:41 AM
LDS LDS is offline
Interesting! I have found the complete opposite to be the case. Even in hybrid mode, I can run lower sample buffers much more reliably than I could using the HDX engine alone in previous versions.
Is there perhaps a plugin in there somewhere that needs an update?
What is the Hybrid Engine? loopzilla2 Pro Tools HDX & HD Native Systems (Mac) 31 04-22-2021 07:11 AM
upcoming Hybrid Engine HDX Option? DetroitT Pro Tools HDX & HD Native Systems (Mac) 16 03-01-2021 04:34 PM
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 12:01 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
