Old 05-22-2013, 08:00 PM
Jmo9 Jmo9 is offline
Default Re: ProTools 10 and Mbox 3G Problems on Windows 7 (64 bit)
I'm sorry to say that holding 'N' down with its resulting window still doesn't list the Mbox as an option.
I also took out the 2GB RAM stick and that didn't solve the problem.
Any other ideas?
Thanks.
Old 05-23-2013, 04:57 AM
Southsidemusic's Avatar
Any other ideas?
Thanks.
Have you trashed prefs and all that described in the "help us help you" and tried the Mbox in all the usb ports aswell? Disconnect everything except the Mbox and do all the optomizations restart and try the "N" thing again
There is probably a simple solution to this but as I am using Macs I am just trying to help you as best I can. Installed latest drivers I expect and still no go?!?
Leave the 2GB ram out of this until we get you going again.
Try the thread with optimizations and hollaback
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-25-2013, 08:52 AM
Holding the 'N' key doesn't solve the problem. Switching USB ports doesn't either.
I'm not sure what you mean by 'try the thread with optimizations.'
I'm still looking for help.
Thanks.
Old 05-26-2013, 01:34 PM
Thanks.
I mean this thread
http://duc.avid.com/showthread.php?t=300050
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 05-27-2013, 09:38 AM
I went into Uninstall Programs and clicked Pro Tools then the Change tab . I then ran the Repair option and the computer installation came up with this message:
MDAC 2.7 sp1 cannot be installed on this machine. MDAC 2.7 Sp1 requires any one of the following configurations:
Microsoft 98 with Y2K Update and Internet Explorer 4.01 SP2 or later
Microsoft Windows Millennium
Microsoft NT 4 SP5 (or greater) and IE 4.01 SP2 or later
Microsoft Windows 2000
Microsoft Windows XP
Setup will exit now. Please restart the Setup after installing the necessary updates to this machine.
I then went to the microsoft website and downloaded what I thought was the update and ran it, restarted the machine, but the same message popped up when I tried to repair Pro Tools again.
Any thoughts about this? I tried to search online for answers and only got further confused.
Thanks for any help.
Old 05-30-2013, 05:06 AM
It seems I need to turn to one of Avid's technicians to try and solve this problem.
As a final effort to fix it myself I uninstalled PT 10 upgrade and re-installed PT 9 from the disc. Problems remained the same.
Thanks to those of you that tried to help.
Old 05-31-2013, 11:47 AM
Yea, I think this is a bit too confusing for me but there might be a good idea to pay $30-40 to get this fixed as you seem to have done alot to fix your probs
Good Luck and hope you get up and running soon
Best Regards
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 05-31-2013, 03:55 PM
zedhed's Avatar
zedhed zedhed is offline
The only thing I couldn't do was power up the Mbox before PC because Mbox is powered by PC.
Have you tried running the Mbox on it's own power supply?
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Mbox 1.1.8 Driver Problems / Windows 8 jimst57 Windows 9 07-31-2013 12:11 PM
Problems With MBox 2 mini on windows 7 zacharyah88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2009 01:39 PM
MBox 2 Pro problems - no sound (Windows XP Pro) charliemizza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-13-2009 10:53 PM
AutoTune 4 - ProTools 6.4 - Windows XP problems drmandel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-02-2004 11:36 AM
Pro Tools 6.1.1/MBox/Windows XP Problems! Help! Josh Jagdfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-26-2004 07:47 AM
