Length of snake from live to control room?
I was wondering if the length of the mic snake that goes from the live room to the contol room makes any diffrence in sound at all. I have been using a 125' snake to go 25', for a couple of years now. Everything sounds fine, but It just hit me that every mike has to travel an extra 100' before it hits the pres. Also phantom has to go an extra 100'. Has anyone seen any change in performance due to long snake runs?
PT HD 10.3.5 Accel 4 x3 192 I/Os (48 in 24 out Analog) Sync I/O Big Ben Control 24 |
Re: Length of snake from live to control room?
Typically, if you're running a balanced +4 system, then you should be able to run a couple hundred feet or more with no problems. Since the signal is traveling near the speed of light, a hundred feet doesn't mean much.
BUT- OTOH, There is the school of thought that the shorter the cable length the better. BUT- OT OOH, there's probably much more than a hundred feet of wiring involved in a typical SSL/outboard/patchbay setup.
Thomas Anthony Natural Sound |
Thanks, Thats what I thought. I do live sound for a living, and I am use to having 300' FOH runs. I am still fairly new in the recording side of audio. So figured Id ask just in case.
Need recommendations - setup control room width or length wise | Java | General Discussion | 2 | 08-25-2009 02:14 PM |
Adding control room with 003 to live venue | mattmarshall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-06-2009 01:35 AM |
Digital Snake length limit | chtam | VENUE Live Sound Systems | 2 | 01-02-2008 07:43 PM |
Snake Length | eytan | VENUE Live Sound Systems | 1 | 12-10-2006 10:07 AM |
Advice Control to live room | ajazzie | Pro Tools TDM Systems (Mac) | 3 | 09-21-2005 01:27 PM |
