Old 03-08-2011, 04:47 AM
scopelinio scopelinio is offline
Angry pt 9 wont play anymore!!??
hi,
as i press play in pro tools eighter spacebar or via mouse on the transport window pro tools 9 wont playback anymore?? it is telling me "pause" and i cant figure out how i got there?
no sync waiting, no pr or postroll, no selection, no loop, no wait for midi,...
i am getting crazy on this one!
i am using pro tools 9.0.0 on a mac osx 10.6.5 with a mbox2
any ideas?
thx m.
Old 03-08-2011, 08:54 AM
KMcK KMcK is offline
Default Re: pt 9 wont play anymore!!??
Have you tried everything in the General Troubleshooting thread already?
Old 03-08-2011, 09:10 AM
Nave128 Nave128 is offline
Did you go to setup>prefs and check that timeline insertion and edit insertion follows playback are checked? I have had
This issue a number of times and toggling those and i believe edit follow scrub as well, resolved it.
E
Old 03-08-2011, 11:29 AM
timeline insertion and edit insertion follows playback edit follow scrub as well
did not solve a thing....
Old 03-08-2011, 01:58 PM
Carl Lie Carl Lie is offline
Is your clock set-up to external?
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 03-08-2011, 02:03 PM
slater05 slater05 is offline
Have you tried switching the playback to core audio?
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 03-09-2011, 12:53 AM
no external clock. core audio has been removed from my computer because of pci troubles...
Old 03-09-2011, 08:56 AM
BaileyBass BaileyBass is offline
Ive had this and going in and changing HW Buffer settings seems to free it up. Then I go back and change to original settings and all is ok.
I do know this can be a symptom of your HW buffer being set too low... where are you with that?
Old 03-10-2011, 08:18 AM
D. Reck D. Reck is offline
I was having the same problem... I followed Digi's troubleshooting steps for deleting the prefs and databases and the problem is fixed.
Old 03-21-2011, 03:04 PM
Nullfusion Nullfusion is offline
same problem. very very annoying. sure glad im not recording a band,
that would be fatal good old hardware buttons.
i changed from logic to my new protools 9 about 1 month ago and besides of a few crashes everything was ok so far.
now this strange problem occured. no play. no nothing. just the bling bling no matter what i do.
i have a newer black MBox and even the new Protools 9.0.2 Update. Still not working. A new blank Session is playing but if i open (from there on) the Sessions that worked just yesterday, they dont.
Tried the IO default. didnt work. I read of this Problem with dates long time ago already in earlier versions.
As i tried to change the Buffersize, and then back again, Protools completely hangs and does nothing even after 15 Minutes, so i have to interrupt it manually. The whole Session actually acts pretty strange. As i tried to remove Plugins it was taking wayyy to long. somethings wrong..
looking forward 4 the true solution..
play flashes then stops. session wont play. hellbert Windows 21 03-31-2011 10:49 PM
keyboard shortcuts wont work anymore glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-10-2009 04:18 PM
protool le 7.4 cs1 just wont open anymore one solo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-04-2009 02:52 PM
BUG?: Tracks that wont make sound anymore Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2006 11:46 PM
Protools wont open anymore. HunterS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-20-2005 05:40 PM
