vocal editing and mixing to do cover songs
Hi everyone!
I'm new to recording and making music, and I would like to do cover songs like these people on youtube http://www.youtube.com/watch?v=IL_sLyWNj7I http://www.youtube.com/watch?v=vZ0qtdywBz8 http://www.youtube.com/watch?v=SF3Rf896yL0 How do I set it to that type of vocal, everytime I record it sounds dry and not in tune/sync with the instrumentals/background sounds How do I edit/mix/compress it like those people, what are the settings/plug ins? THANK YOUU!!!!! |
Re: vocal editing and mixing to do cover songs
You have to learn to walk before you start running. Recording is an art and you don't learn it overnite, or with 1 question to the DUC(no offense intended here as all of us started off with no knowledge or skill). It takes a good voice, a good mic, a good preamp, a good sounding room, followed by proper treatment(EQ, compression, effects). All this needs to be done on good speakers in a treated room.....there's a lot going on here and experience is the best teacher, so dive in. As for SYNC, it could be latency from plugins, or recording with a high buffer(record at 64, and no plugins on the master track). As for tune/pitch, if you aren't singing in tune(and many don't) then you need a good tuning program(AutoTune, Melodyne, Waves Tune, etc) to fix the tuning(and it takes a certain level of musical talent to tune) How do I edit/mix/compress it like those people, what are the settings/plug ins? What settings and plugins are really unique to every vocal(assuming we are concentrating on vocals here) so telling you what to do without hearing what you HAVE, is like coloring by numbers. Use a compressor to even out the levels(volume) so the vocal stays at a more even volume(I use AudioSuite GAIN to level parts that are too soft or too loud, before adding a compressor). With EQ, start with a HPF(hi pass filter) to remove rumble and garbage below the range of the vocal(like most everything under 150Hz). Then, take any EQ band and set for a narrow and serious boost(like +9) and sweep the frequency while playing the track. When you hear "ugly" jump out, that frequency needs to be cut(start with -3). Repeat with a few more EQ bands(what this does is reduce the peaky areas for a smoother, more pleasing sound). If you can do it well, singing the same part twice(double-tracking) can sound great(but if you can't do it well......). Use reverb and delay sparingly(and always insert those plugins on AUX tracks and use sends to feed them). Try shorter reverb on faster songs(like 2 seconds of decay) and very short delays(like 60-100ms). IN any case, this should be a good start, so let the learning begin
Thank you for the helpful tips and getting me started, i have a lot of learning ahead of me.
(and always insert those plugins on AUX tracks and use sends to feed them) how do i insert the plugs in on aux tracks and send to feed them? and what does it do? sorry for the newbie questions! and thank you so much for helping me out and the only person to answer these newbie questions MUCH APPRECIATED!!! |
Hi.
I just bought a video camera, and while I have no idea how to use it, could someone please tell me how I can make films like Martin Scorsese? Thanks. I'm a video noob.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
First, you need to get a bunch of millions of dollars... then call me... it will be great.
should i add any vocal plug ins? like sans or airtalk ect..
and thank you for taking the time to answer my questions |
You should add the plugins that get you the sound you want. Try everything(you need to do this to learn what plugins make what sounds). Its all part of the learning curve so be patient and dive in(just don't expect to make a hit recording on your first time out.....or second..........or eighteenth......). Every person learns at their own pace, so you have to find yours. Part of this learning will teach you how to ask better questions( I know that sounds odd, but it really is true) so we'll be here(but try to learn some on your own as it will make you a better engineer).
Ive been staying up to learn pro tools and im starting to get the hang of it, but i have a problem with my mic i think, every time i sing and record, my voice sounds deep, but my voice isnt that deep, im not sure if i have the right mic, im currently using audio-technica at4040, my pop filter is 2 inches from the mic and im standing 2 inches from the pop filter, so im about 4 to 5 inches away from the mic everytime i sing and record.
why does my vocal sound so deep every time i record? i also switched it to low past and -10db on the mic PLZ HELP AND THANK YOU!!! |
i'm new to medicine, but would like to do brain surgery like these people...
http://www.youtube.com/watch?v=M68GeL8PafE i have a saw just like they do, but how do i use it? |
How to obtain vocal sound like rap songs today? | Neruk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-16-2006 01:12 AM |
mixing 5 songs with the same eq/compression | mr razor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-04-2006 04:00 PM |
editing songs from mac to pc | rbernsen | Storage Subsystems | 0 | 07-01-2005 02:49 PM |
Mixing 10 songs in 10 hours | wikked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 01-19-2005 06:34 AM |
Creating loops, editing songs | SteveU | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-24-2002 01:16 PM |
