Pro Tools keeps doing strange errors
1. Memory violations
2. Sometimes it says that Pro Tools is running really low in memory even when I hardly have anything loaded in it. 3. The other day I got an error I've never had before. When I saved my project, it said it couldn't save because the session was "end of stream". I could not open the session anymore either. It said something like this.... Pro Tools "start up session commmand has been disabled because of an end of stream error"??? 4. Pro Tools always has problems every time I save a project. I mainly get something like an access violation error or something like this, and also memory violations when yet again I've hardly reached the limit. This only happeneds when I save a project. I know when the problem has happened because when I save, at first it doesn't save, then I save again and I have to shut PT down. Also, PT decides to delete it's own sessions off my hard drive when I save my projects and this is just [bleep][bleep][bleep][bleep]ting me up the wall because I keep losing my work! Here's a sandra report. SiSoftware Sandra Computer Model : Gigabyte EX58-UD5 Workgroup : WORKGROUP Host Name : Dan-PC User : Dan Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD5 BIOS : Award (Phoenix) F3 11/14/2008 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 24GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Total Memory : 24GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 540MHz (1GHz) Memory Module(s) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Memory Module : Corsair CMP12GX3M3A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (8-8-8-23 5-31-9-5) Video System Video Adapter : NVIDIA GeForce 6500 (Microsoft Corporation - WDDM) (4 PS3.0, 3 VS3.0 398MHz, 128MB DDR3 2x702MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 6500 (Microsoft Corporation - WDDM) (4 PS3.0, 3 VS3.0 398MHz, 128MB DDR3 2x702MHz, PCIe 1.00 x16) Graphics Processor Storage Devices SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (E:) SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (F:) WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (G:) Seagate ST3250310NS (250GB, SATA300, 3.5", 7200rpm, NCQ) : 233GB (C:) WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (H:) PIONEER DVD-RW DVR-218L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) FWRSJ LY3CDAZ4 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (I:) Logical Storage Devices Prod 1 (E:) : 932GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Prod 2 (F:) : 932GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Prod 3 (G:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Hard Disk (C:) : 233GB (NTFS) @ Seagate ST3250310NS (250GB, SATA300, 3.5", 7200rpm, NCQ) Prod 4 (H:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (D:) : N/A @ PIONEER DVD-RW DVR-218L (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (I:) : N/A @ FWRSJ LY3CDAZ4 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Disk Controller : Giga-Byte 6 port SATA AHCI Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter 1 : NETGEAR RangeMax(TM) Wireless USB 2.0 Adapter WPN111 (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9
PC - Intel i7 920 Quad - 9GB RAM - EX-58UD5 - 5 HDs - Windows 7 64bit Audio Interface - M-Audio Profire 610 Pro Tools - M-Powered 8.0.4 FL Studio - 9.0.3 Midi controllers - Behringer BCF 2000 - M-Audio Keystation 61es Dan-Jay |
Re: Pro Tools keeps doing strange errors
Just did it again!!!!!
Saved my work, I got an access violation thing, than my session is no longer on my hardrive!!!! WTF!!!!
Really.........? Not one response yet.
Is there a number I can call? Look, I just really want to call someone and explain what's happening. I need help.
Is this happening to all you sessions or just a certain one?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Have you done this?
Delete Digidesign Databases and Preferences To delete Digidesign Database folders for all hard drives in Windows 7: * Go to your Start menu and click on Computer. * Double-click on the C: drive. * Double-click on Program Files. * Go to the Digidesign folder. * Go to the Pro Tools folder. * Right-click on the Databases folder and delete it. * NOTE: If you are using Pro Tools HD, DV Toolkit 2 or Complete Production Toolkit, you will want to backup your Catalogs folder before deleting the Databases folder. To delete Pro Tools preference files in Windows 7: * Go to your Start menu and click on Computer. * Double-click on the C: drive. * Double-click on Program Files. * Go to the Common Files folder. * Go to the Digidesign folder. * Go to the DAE folder. * Right-click on the DAE Prefs folder and delete it. * Go back to your C: drive. * Double-click on Users. * Double-click on your user name. * Go to the AppData folder. * NOTE: If the Appdata is not showing, click on Organize and choose 'Folder and Search Options'. * Click on the View tab. * Select 'Show Hidden Files and Folders'. * Click Apply and OK. AppData should now be viewable. * Go to the Roaming folder. * Right-click on the Digidesign folder and delete it.
You can also delete the WaveCache.wfm and the Fade Files from the session folder.
It has fixed problems I have had before when trying to save a session.
I've done all the deleting preferences stuff. I di this today before I opened up everything. It seems to be doing on this certain one, worse than the others and I don't know why!
I really want to get my work done. There has to be a number or something. Gahhh I'm glad I got a response though. I tried the cs2 update and that didn't do much either. This is never ending........... really
I'm not sure if I'm supposed to delete the pref folder everytime I load up the computer next or. Someone said you only need to do it once which would make sense because you don't want to be changing the prefs all the time.
Where is someone from DIGI!!
Try this in the session folder you are having the most trouble with.
Death Of DAE errors and Pro Tools Errors | ReynaldoPena | Windows | 17 | 11-13-2012 11:33 AM |
pro tools strange | noelooo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-03-2008 07:13 AM |
errors errors errors Please digi tech guys help me | dunkyj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-11-2005 01:19 PM |
-7053 DAE errors and other strange stuff | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 4 | 02-09-2003 05:41 PM |
A FIX for strange -9128 errors and USB interfaces | emaginaryrecords | Digidesign Hardware & Software | 1 | 02-27-2002 03:19 AM |
