Is 8.0.1 Reliable with HD2, Leopard, and G5?
Hi.
I'm still running an HD2 system v.7.4 in Tiger and I'm quite happy. Although I'm considering moving to Leopard and PT Version 8.0.1. Who out there is running a similar system? Is this a stable setup? Thanks. |
Re: Is 8.0.1 Reliable with HD2, Leopard, and G5?
I have the same system, and this weekend did the update to Leopard and PTHD 8.0.1. It took awhile because I had a snag while installing Leopard. Eventually, the install and subsequent updates (I'm on 10.5.5) worked, and PT8 seems to be humming along nicely, sessions all day yesterday went well.
We've been on OS 10.5.8 for quite awhile, running PT 8.01cs2 on 4-G5s that are 6-years old. No problems at all!!
One system is an HD2, the other 3 are HD1.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Running G5 Dual 2.3 PCI-X machine, Mac OSX 10.5.8, Pro Tools 8.01cs2, with 8 year old Magma 32bit 33mhz Expansion Chassis with no problems!!
Mac Pro Early 2009 3.06 Six Core 48gb ram, Pro Tools 10.3.10, HD6 Accel, Pro Tools 2021, Macbook Pro, Magma PE6R4i, Yamaha DM2000 Console, Logic 9 and 10, Apogee Big Ben, 10pcs HD 192's, Benchmark DAC-1, Distressors, API, Neve, Rupert Neve, Dangerous, Lynx, Manley ELOP+, Massive Passive, VariMu, Neumann, Peluso, A-Designs Hammer 2 & Nail, Empirical Labs, Drawmer, Lexicon U87, Bricasti M7, dbx, Cranesong, SSL 500 G-Bus, Custom Audio Germany, Dynaudio, Focal, Yamaha, TC Electronic, Mapex Drums, SPL |
Thanks for the positive news. Is it safe to say I should go with 10.5.8 and 8.0.1cs2?
Thanks. |
two rigs, HD3 and HD2. OS 10.5.8, PT 8.0.1cs2, G5 (don't know specs, i think quite old), no problems.
in fact many problems fixed from the old 10.4 and 7.4 rig, but that's prob just fixing the bad install rather than actual 10.4 and 7.4 issues. as an OS, 10.5 is much better than 10.4 for everyday things, especially networking. |
Make sure your plugins are 1000% compatible. REMOVE all non-compatible plugs from your plugins folder.
--Jeremy |
Yes.. very stable here as well. sb
my issues are less about stability/reliability -- how's the midi by the way?
(i've stated more times than i care to really) but more about GUI darkness dreary vibe and certain "go to" plugin incompatibility mainly my TDM UA bundle it would be quite frustrating to re vamp a lot mixing progress commitments of projects i am spending a lot of time on both of my own personal CD and a client who i have 8 CDS in the can on and really are not nailed down with final final mixes... i want to be able to revisit my past work and not have to change what i already love because of a software upgrade....someday i will but not now. i choose to hold THAT TIGER fast on 7.4like a big dog.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
All stable here using two g5 systems just follow the advice above and you should be ok
What is the most reliable Mac OS to use with PT LE 8? | larrycom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-22-2010 08:50 PM |
7.1 cs8 is very reliable now :) | crizdee | Pro Tools TDM Systems (Mac) | 34 | 07-17-2006 03:01 PM |
1 Ghz G4 more reliable than 1.25 Ghz? | didger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-09-2003 12:21 AM |
1 GHz G4 more reliable than 1.25 Ghz? | didger | Pro Tools TDM Systems (Mac) | 0 | 07-07-2003 04:44 PM |
Most reliable HD? | Marc Edwards | Tips & Tricks | 12 | 02-14-2001 04:34 PM |
