PT9 bounce error 6101
PT9 I can bounce only at 1024 buffer size, it's normal?but I can record and play
at every buffer. without plugin and one track. if i try to bounce to 512 stop and appear the error 6101. iMac 27, 8Gb ram,1TB HD 7200 rpm,Mbox 2 pro with new driver for PT9. thank you bob |
Re: PT9 bounce error 6101
I have the same problem. but, I try bouncing sessions made it in pro tools 8.0.4 and show me an error that said that need increase the buffer size(in 8.0.4, I can bounce in 512mb buffer size). in pro tools 9, I can't do it.... I guess that is a problem related with the optimization of the software. we need wait for the next update.
Just found that thread here.
Is that issue now solved ? Are you both on OS X ? Have you tried installing it on Windows 7 x64 just to try if it works ? |
Are you guys using secondary internal drives or external firewire drives?
Are you using convert after bounce or during?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I am having a problem where the first bounce works fine, but if I try to bounce again Pro Tools will crash immediately.
PT 9/iMac Core 2 Duo 2.66/2Gb Ram/PT9/Mbox 2 Pro External FW 500Gb Seagate 7200rpm convert after bounce or no conversion All plugs updated and all troubleshooting procedures have been done. Last edited by chroma17; 12-03-2010 at 10:08 AM. Reason: mo' details |
I have been using a different internal HD 300gb 7200rpm from the HD used by the MacosX and the problem is the same. I remember when I upgrade from pt7.4 to pt8 the bounce problem was relate with the use of the pro tools resources and with the updates was solve the problem . I guess that is a problem related with that, the resources that use pt9 to work. I hope that the update could give for us the solution!
I found a possible solution!! if you had an interface that can work at 96khz, you can save your sessions at 96khz and the 2048 buffer size option appears! and you can do the bounce.
Have you done all the General Troubleshooting steps, especially disabling Bluetooth?
I must say, I'm able to do 10-20 bounces just fine.
OS: Windows 7 Home Premium 64-Bit DAW: Protools 9 & Sonar Producer 8.5 CPU: AMD Phenom X4 940 3GHz RAM: Kingston 1066 DDR2 4GB MoBo: ASUS M3A78 Video: Saphire ATI Radeon 4850HD 1GB Other: UAD-2 Duo Interface: Presonus StudioLive 16.4.2 & Firestudio Mobile |
I can't disable the bluetooth connection because I use an apple magic mouse with my mac.
Bounce to Disk problems - 6101 CPU Overload | alexdude777 | macOS | 3 | 12-26-2013 01:54 PM |
PT 10.2 6101 error. NEED HELP! | Stijn Cole | macOS | 0 | 07-01-2012 02:27 AM |
error -6101 | PMcC | macOS | 3 | 02-15-2012 02:47 PM |
-6101 error | sykobilly65 | Pro Tools M-Powered (Mac) | 2 | 02-15-2012 07:38 AM |
6101 error on bounce (not while playing or recording) | pkm | macOS | 11 | 09-22-2011 04:55 AM |
