Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 05-18-2022, 09:20 AM
martthie_08 martthie_08 is offline
Default Syncing Pro Tools Carbon to external timecode
I still have a HDX rig that works with Sync HD but really want to use my Carbon for mobile gigs. What are the best options to slave ProTools to external timecode provided by the video crew?
Old 05-18-2022, 10:14 AM
BScout BScout is offline
Default Re: Syncing Pro Tools Carbon to external timecode
Lockstep from Figure 53 is the best LTC to MTC translator I've found (better than the really unreliable one from Source Connect.) Bonus is it's free
https://figure53.github.io/studio/
So you point to an audio input on your system that is getting LTC coming from the vid crew (this has to be an additional audio interface not being used by Pro Tools -- could be even system input) and then redirect the MIDI timecode Lockstep generates to any MIDI port or IAC MIDI (software MIDI built into macOS.) Then set Pro Tools to listen to that MIDI port for MTC.
Old 05-23-2022, 01:34 AM
fantastic, thank you so much, I will check it out!
Audio Timecode with protools, syncing with video [email protected] Pro Tools 26 10-03-2021 03:40 AM
Carbon Delay Comp with external hardware? tomhartman Pro Tools | Carbon 2 09-04-2021 08:41 AM
Carbon - External Source Monitoring [email protected] Pro Tools | Carbon 5 01-29-2021 01:50 PM
Import syncing timecode stamped audio in Pro Tools? illution1 Pro Tools 2018 1 03-22-2019 03:53 AM
Syncing Timecode DAT to PT? IO Composer Post - Surround - Video 6 10-20-2003 10:58 PM
