Old 03-03-2022, 04:29 PM
rinky rinky is offline
Default IK's Axe I/O record to Pro Tools
My Mac Pro 7,1 recognizes my AXE I/O. It works in standalone.
But how can I make this available in Pro Tools so that I can play and record within Pro Tools?
Anyone got this working?
Thanks in advance.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 03-04-2022, 06:14 AM
creativecontrol's Avatar
Default Re: IK's Axe I/O record to Pro Tools
There are standard CoreAudio drivers - so you should simply be able to go to Setup > Playback Engine in Pro Tools and choose AXE IO as your engine.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-04-2022, 07:03 PM
Thanks for this info! Will try it out soon!
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Old 03-07-2022, 03:16 PM
Hi Jeff.
So that didn't work. AXE IO was selected and obviously PT's playback was disabled (no output with my HDX).
What I was actually asking is how can I integrate AXE IO so that I can access it and record my guitar within PT? Sorry for the confusion.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Old 03-07-2022, 07:52 PM
nst7 nst7 is offline
You mention trying to use HDX. I'm not sure exactly what you're doing, but this is an either/or situation. If you select AXE IO as your playback engine, you can only use it, and not HDX. It becomes your interface. There's not a way to use both at the same time. You would switch to the AXE IO as your interface, record through it, and monitor using headphones (or monitors) plugged into the AXE IO. Then when you're done, you would switch everything back to HDX for further recording and mixing, etc.
Old 03-08-2022, 02:38 PM
Yeah, understood. Initially I thought I can record my guitar via AXE IO to Pro Tools directly. Thanks for the feedback.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
When I press record, I don't want Pro Tools to record the note I'm currently holding Electronic1982 Pro Tools 12 2 05-15-2017 02:39 AM
Pro Tools 10 won't record highspeedrecords Windows 2 02-27-2012 05:55 AM
Can't get Pro Tools LE 8.05 to record gregklau Eleven Rack 2 01-30-2012 03:34 PM
Pro Tools 9 record help! Peter Dutton Pro Tools 9 4 11-26-2010 08:09 AM
Pro Tools will NOT record! tunecrab Pro Tools M-Powered (Win) 1 05-25-2007 06:56 PM
