Blasts of White Noise & Pops
About 2 weeks ago and about 3 days before I installed the 9.0.3 my PT9 started hanging, crashing, quitting partway through the startup and now...it starts but about every 15 seconds I get a huge blast of white noise with pops in between.
I'm on a PC. Anyone have any suggestions? I appreciate any help! Thanks, Allen |
Re: Blasts of White Noise & Pops
We need a lot more info, and ideally a Sandra report. Help us Help You - READ THIS Before Posting!
Allen |
Hope this is what you wanted.
Thanks, Allen SiSoftware Sandra Computer Model : MSI MS-7235 Workgroup : WORKGROUP Host Name : User-PC User : Allen Processor Model : Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz Speed : 2GHz Cores per Processor : 2 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : MSI MS-7235 BIOS : Phoenix Technologies, LTD 6.00 PG 06/13/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR2 Chipset Model : Intel P965/G965 Memory Controller Hub Front Side Bus Speed : 4x 280MHz (1.12GHz) Total Memory : 8GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 6.18GHz (12.35GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HYMP125U64CP8-S6 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP125U64CP8-S6 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP125U64CP8-S6 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP125U64CP8-S6 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : Radeon X1300/X1550 Series (PS3.0, VS3.0 445MHz, 256MB 297MHz, PCIe 1.00 x16) Graphics Processor Storage Devices WDC WD4000YR-01PLB0 (400GB, SATA, 3.5", 7200rpm, 8MB Cache) : 373GB (G:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:) WDC WD740ADFD-00NLR1 (74.4GB, SATA150, 3.5", 10000rpm, 16MB Cache) : 69GB (E:) WDC WD1600JS-00NCB1 (160GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 149GB (F:) SanDisk U3 Cruzer Micro 4GB (USB) : 4GB (H:) HL-DT-STDVD-RAM GSA-H22N (RAID, DVD+-RW, CD-RW) : 3GB (D:) Logical Storage Devices Storage (G:) : 373GB (NTFS) @ WDC WD4000YR-01PLB0 (400GB, SATA, 3.5", 7200rpm, 8MB Cache) Reserved : 100MB (NTFS) Ripping (E:) : 69GB (NTFS) @ WDC WD740ADFD-00NLR1 (74.4GB, SATA150, 3.5", 10000rpm, 16MB Cache) Hard Disk (F:) : 149GB (NTFS) @ WDC WD1600JS-00NCB1 (160GB, SATA300, 3.5", 7200rpm, 8MB Cache) Removable Drive (H:) : 4GB (FAT32) @ SanDisk U3 Cruzer Micro 4GB (USB) Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) RhythmCraft (D:) : 3GB (CDFS) @ HL-DT-STDVD-RAM GSA-H22N (RAID, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Intel 82801HB/HR (ICH8/R) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627EHF/EF/EHG/EG Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : MSI 82801H (ICH8) 4 port SATA Controller Disk Controller : MSI 82801H (ICH8) 2 port SATA Controller Disk Controller : MSI JMB361 AHCI/IDE USB Controller 1 : MSI 82801H (ICH8) USB UHCI #4 USB Controller 2 : MSI 82801H (ICH8) USB UHCI #5 USB Controller 3 : MSI 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : MSI 82801H (ICH8) USB UHCI #1 USB Controller 5 : MSI 82801H (ICH8) USB UHCI #2 USB Controller 6 : MSI 82801H (ICH8) USB UHCI #3 USB Controller 7 : MSI 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : SanDisk U3 Cruzer Micro (3.74GB) Network Services Network Adapter : Realtek PCI GBE Family Controller (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 3.9 |
disable the net card?
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
How do I go about that?
Allen |
I could not be more embarrassed , but, I shall nevertheless post my "solution". And, yes, I was supposed to be aware of this.
I have an IKMEDIA bundle that most of which I had registered but when I inserted any of the IK plugins into a session, then the expired plugin would give it's white noise "blast"....even if it was not the plugin being used. I have registered them all and ...no problems. Allen |
Well done troubleshooting it yourself. A+, Sir.
Mike.
Blasts of white noise and sync errors??! | sknoof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-05-2010 06:52 PM |
Random Blasts of White Noise | TNDoug | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-14-2007 10:42 AM |
Blasts of white noise in LE systems. Forever? | easyb | Tips & Tricks | 26 | 02-02-2007 06:38 AM |
White Hot M-BOX Noise Blasts! Please Help! | Derek Doublin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-17-2004 10:47 AM |
Protools 6 white noise blasts - little help? | roryrok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 29 | 03-07-2003 11:40 AM |
