Old 04-22-2007, 06:55 PM
teacherman teacherman is offline
Default 7.3.1 Record button doesn\'t flash during Quick Punch
I've worked on several different ProTool rigs in the past week. All PT rigs were running HD 7.3.1. CS2 on Macs.
I noticed that when a track is armed and ProTools is in play mode, the Record Button on the transport in the top of the Edit Window (as well as the ICON and Procontrol Transports) does not flash during Quick Punch as it did in all previous versions of ProTools.
Has this feature been purposely omitted? Or is this just an oversight that will soon be fixed?
Thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 04-23-2007, 05:34 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: 7.3.1 Record button doesn\'t flash during Quick Punch
All flashing fine here on 7.3.1cs2.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-23-2007, 08:54 AM
Hey Chris,
Glad to hear that.
I wonder why the 3 different different ProTool rigs that I just worked on this past week did not have the "flashing" record button???
Hhhhmmmmm!
Anyone from Digi want to jump in on this???
Old 04-23-2007, 11:56 AM
Just went back and forth between to 7.2 and 7.3.1. several times.
Everything is okay in 7.2. Problem still exists in 7.3.1.
I varified this with the other studios. They are experienciing the same results.
Old 04-23-2007, 03:19 PM
crizdee's Avatar
Ok, i think i can see what you mean? with the transport running and you're in quick punch.
so before 7.3.1 the button used to flash when the transport was running?? then go solid red when punched in! but now it stays unlit when the transport is running.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-23-2007, 05:04 PM
sleadley sleadley is offline
The record light will only flash on a second machine locked to a master Pro Tools system during the Pre-Roll period. This has been a problem when using a second Pro Tools system as a Mix machine for ages. if you turn off the Pre-Roll The record light will not come on till the insertion point (assuming that you haver the "record at insertion point" enabled. This mayt be related to the problem you are seeing, but I cannot be sure as I am not near my TDM system at the moment. But I will look when I get to work and report back
regards
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 04-24-2007, 06:45 AM
Yes Chris! What you just summerized is Exactly what I'm talking about.
Thanks.
Old 04-24-2007, 06:51 AM
Thanks for the reply Simon L....But I think you've missed the point. You're talking about a whole other unrelated issue.
Please read Chris's lastest post (just before yours). He nails the problem perfectly.
Again, DIGI....any fix on this?
Old 04-24-2007, 12:00 PM
Kenny Gioia Kenny Gioia is offline
Mine isn't flashing either.
Digi seems to have this theory of changing things for the sake of change.
Same with Automation on my control24.
The red lights used to blink until you touched the fader but now it's reversed. It's solid until you touch it, and then it blinks.
They're trying to drive us crazy. I know it.
Old 04-24-2007, 04:31 PM
I did understand your question, I was simply relating a similar problem that might have related to yours. I don't see this on my system in QP
best regards
Simon L.
My record/quick punch bug list Vedat macOS 0 12-19-2011 11:53 PM
Loop Record - Quick Punch! Inflict 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-04-2011 05:32 PM
PT9 - Quick Punch voice Limitations during record? faraway1982 Pro Tools 9 3 11-06-2010 06:50 PM
Quick Punch Record Enable Jeremy Lock Post - Surround - Video 3 03-05-2007 03:43 AM
quick punch pre/post record Mt.Everest Pro Tools TDM Systems (Mac) 1 07-17-2002 12:28 AM
